Proper birfield maintenance? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2012, 09:18 AM   #1
989F150904
Mud bogging is addictive
989F150904's Avatar
Default Proper birfield maintenance?
I wheeled my truck for the last 2 years and from what I've been told the birfields are the weakest part of the Yota axles. So befor I have a problem and have to find out the hard way how to fix/replace/repair these, what should I do?
989F150904 is offline   Reply With Quote
Old February 10th, 2012, 01:02 PM   #2
What size tires are you running?
Basically, to get at them, you need to remove the spindle. So find a service manual and learn up on how to do basic maintenence. You should learn how to service your hubs and bearings anyway. Once you are there, its not that much harder to get at the birfields.
COmplete front end work:
http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
How to separate the birfield stub from the inner:
A different/quicker way to do it on the trail without taking about the spindle:
By the way, in my experience, the best way to get cone washers off (behind the nuts on the locking hubs and on the knuckle studs) is to back the nut off most of the way, then use an air chisel with a rounded/blunt tip on the end of the stud. The only thing I've done that pops them off 100% of the time.
Old February 10th, 2012, 02:39 PM   #3
989F150904
989F150904's Avatar
Very helpful. Thank you Jesus
Old March 25th, 2012, 01:54 PM   #4
cerial
Direct Drive FTW
cerial's Avatar
That's some excellently written tech. Very impressed.
Page generated in 0.23720 seconds with 36 queries
