no overdrive on 94 explorer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2006, 01:03 PM   #1
xlinkinpark2438x
03 Rubicon
xlinkinpark2438x's Avatar
Default no overdrive on 94 explorer
i have a 94 explorer with 4.0 and automatic trans
the trans only has 30k miles on it
the trans wont shift into overdrive and i was woundering if this has happend to anyone else
someone told me that they had the same problem and it was a bad sensor
Does anyone know what or where that sensor is?????
any help please
thanks
xlinkinpark2438x is offline   Reply With Quote
Old October 4th, 2006, 01:27 PM   #2
Bones
Bones's Avatar
try www.explorer4x4.com
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 5th, 2006, 05:30 PM   #3
chris1044
chris1044's Avatar
well, you've the notorious A4LD.....that trans blows balls, bad...it's very very week and notorious for blowing the pump seals and sucking in general.....one thing that helps these tranny's last is driving in drive unless you actually need OD - this uses a band to hold the overdrive drum instead of a multiple disc clutch which is much stronger...but back to your issue
First, are you sure you don't have OD or is it that you dont have TCC lock up?
TCC lock up is controlled by the following:
# Application of brakes (Brake switch located on the pedal assy)
# Closed throttle (TPS)
# Cold engine (ECT)
# Very heavy/wide open throttle (TPS and MAF)
# Low engine speed to minimize lugging boom
# 23.5 inches of mercury absolute barometric pressure or below in the intake manifold. (calculated from MAF)
Most of these will inhibit OD shifting as well, and other things such as a vacuum leak (if it's large eneough)
If you dont have OD, your no OD shift could be caused either by an electrical problem or mechanical problem (inside tranny)....I can't remember exactly what's needed to allow the OD shift (electronically) without looking at a diagram. Also, the kickdown cable could possibly be stuck inhibiting OD operation as well.....
If it were me, first I'd check the input to the OD solenoid while driving it - you can do this with a DVOM back probing the correct wire on the trans and routing it into the vehcile. If it's getting 12v at the correct time, all the inputs are good and the issue is something inside the trans (solenoid/seal/clutches worn out). If not, it's an elec issue such as a break in the wire down to the trans (unlikely), a bad input to the PCM, etc.....
Basically, I know it sucks, but you need a manual and some good diag skills....
Page generated in 0.21657 seconds with 32 queries
