96 f250 eo4d in limp mode - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 9th, 2012, 01:44 PM   #1
tom77cj5
tom77cj5's Avatar
Default 96 f250 eo4d in limp mode
My trans in one of my plow trucks started acting up last week and before I drop the pan I figured I would ask here. If you put it in d it stays in first unless you shift manually to second then if you shift back to drive its like it goes into neutral. I've changed the vss. On the rear diff, pulled the cover to make sure the tone ring is good and changed diff fluid. Been scanned with a totl snapon scanner and has no codes. I've cleaned all the trans plugs and took apart the power distribution box to look for broke wires. No blow fuses. When it doesn't shift it throws the abs light but no code. Also swapped in a diff abs controller to no avail. This year is the easiest plowing i've done. I basically get payed to drive around so I know its not been beat and it hasent gotten over 160*. Also had the alt tested and it's good. Any help is appreciated
Old February 9th, 2012, 03:36 PM   #2
Elvis13
Did you check the soleniod packs or plastic box on the side where the linkage hooks up?
Old February 9th, 2012, 11:20 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
could be a TPS sensor.
Old February 9th, 2012, 11:39 PM   #4
92FleXj
stacks stacked on stacks
92FleXj's Avatar
I had a similar issue with my e40d. I changed the tps and it fixed the problem. I also had another e40d with same thing and it was the MLPS on the shift arm.. Do not mess with drooping the pan until you change both o these first!!
I replaced my trans and the new one had the same problem.. Come to find out it was my EEC. I replaced it and good to go.
If I were you 100% start with the tps.. Then the MLPS
Old February 9th, 2012, 11:48 PM   #5
tom77cj5
tom77cj5's Avatar
Cleaned both connections. Tps tests fine or the scanner says it does. If anything I would try the mlps but im getting tired of throwing $ at it. Any way to test that switch
Old February 9th, 2012, 11:49 PM   #6
92FleXj
92FleXj's Avatar
Tests with a scanner or with volt neater?
Old February 9th, 2012, 11:52 PM   #7
92FleXj
92FleXj's Avatar
Vss, tps, EEC, and MLPS are the only things that would make it do that. I would say tps if not MLPS
Old February 10th, 2012, 12:11 AM   #8
tom77cj5
tom77cj5's Avatar
Pm'd you
Old February 10th, 2012, 05:05 PM   #9
tom77cj5
tom77cj5's Avatar
Changed tps and mlps no change just like I figured
Old February 20th, 2012, 06:08 PM   #10
tom77cj5
tom77cj5's Avatar
so between both of my 90s era plow trucks they have different computers so thats out. i just remembered i changed the filter and fluid this fall when i changed the trans cooler lines so maybe the filter fell off since that seems to be an issue with these trucks? either way im going to have to drop the dam pan once i have time to get it in the garage and check it out.
i need the f6uf-12a650-nb computer if anyone has one i can try.
i found one for 99$ just waiting to findout if its from a ecm company or some backyard chopshop since i'm almost sure i will be wasting another $100 bucks on buying a computer and having the same issue
Old February 20th, 2012, 06:24 PM   #11
92FleXj
92FleXj's Avatar
See if you can return it of it don't work. Buy one from autozone
Old February 22nd, 2012, 11:50 PM   #12
tom77cj5
tom77cj5's Avatar
Fixed it. Mf switch was bad. No idea how it caused it but all back to normal again
Old February 23rd, 2012, 07:57 AM   #13
92FleXj
92FleXj's Avatar
Ware is the mf located?
Old February 23rd, 2012, 09:50 AM   #14
tom77cj5
tom77cj5's Avatar
Turn signal switch. Hazards were on but bony work. Turned them off and its fixed lol
Old February 23rd, 2012, 10:18 AM   #15
TopGunn
Burried
TopGunn's Avatar
Send a message via AIM to TopGunn Send a message via MSN to TopGunn
Weird lol my bronco will turn off cruise and turn off overdrive when I have a blown brake light bulb and use turn signals.
TopGunn is offline   Reply With Quote
Page generated in 0.34656 seconds with 68 queries
