1999 XJ w/4.6L stroker****SOLD***** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 9th, 2012, 07:09 AM   #1
Cherokee Steve
Powdercoating Guy
Default 1999 XJ w/4.6L stroker****SOLD*****
Hi All,
I need to sell my '99 Cherokee. It has a 4.6L stoker, but it needs a new cam and lifters. Newer AW4 trans from Pavement Pounder. Suspension updated last spring, Rough Country long arm, new shocks, ACOS, new brakes(frt&rear). Newer D30 in the front with WJ outers & brakes. New hub bearings. Over the axle steering with chevy 1-ton TRE's. New 3 core radiator with dual electric fans, one computer controlled & one manual. Chrysler 8.25 rr axle. JCR frt winch bumper with Cibie lights. It also has newer bitch tires on steel wheels and 32 X 11.50 tires on aluminum gambler wheels. 2" wheel spacers and SS brake flex lines. Body is in decent shape a little surface rust. The hood has the chrysler turbo vents. It also has a custom roof spare mount and is snorkled. There's more and some spares, but I'm tired of typing.
$1500.00 Firm
If interested, call 810-531-6452, if I don't answer just leave a message.
I'm getting out of wheeling and can't aford to drive this 90 miles to work on a daily basis.
Steve
Cherokee Steve is offline
Old February 9th, 2012, 08:44 AM   #2
mojave01x2
mojave01x2's Avatar
Got any pictures
mojave01x2 is offline
Old February 9th, 2012, 08:48 AM   #3
gladiator18
66' Gladiator
gladiator18's Avatar
Originally Posted by mojave01x2 View Post
got any pictures
x2
gladiator18 is offline
Old February 9th, 2012, 09:10 AM   #4
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
I have personally seen this XJ and wheeled with Steve from time to time. This XJ has been well taken care of and not wheeled hard at all. It's a steal at $1500 in my opinion.
mudviper is offline
Old February 9th, 2012, 11:05 AM   #5
holland_cherokee
do you have any pics?
holland_cherokee is offline
Old February 9th, 2012, 11:40 AM   #6
Cherokee Steve
Powdercoating Guy
Thanks Mudviper. Pics will be posted tonight. Reason for reasonable price is I need to sell quick to finance new DD.
Old February 9th, 2012, 11:58 AM   #7
green50gt
Got rocks?
green50gt's Avatar
Subscribed.
I heart Jeeps
green50gt is online now
Old February 9th, 2012, 05:37 PM   #8
Cherokee Steve
Powdercoating Guy
Default Pics added
BTW, I want everybody to know that I know it needs a cam and lifters because the cylinder head is off. Just want to make sure you realize this. Also, I have a home made on-board air tank (CO2) for an extra $50 to go with it.
ID:	89058   Click image for larger version
ID:	89059   Click image for larger version
ID:	89060   Click image for larger version
ID:	89061   Click image for larger version
ID:	89065   Click image for larger version
Old February 9th, 2012, 08:10 PM   #9
osweezea
I would believe most of the people interested would be thinking of the stroker in their heeps, so couls we get some more info on how this stroker was built?
osweezea is online now
Old February 9th, 2012, 08:30 PM   #10
Cherokee Steve
Powdercoating Guy
Motor was bored .030 over and had a 258cid crank and rods installed. New stock .030 pistons, moly rings, Valves and seats were ground. Rods were reconditioned and crank was ground .010 under and a HV oil pump was installed. Had a comp cams mild RV cam (p/n 58-232-4) installed with matching springs, hesco retainers and locks used. Reciprocating assembly was balanced. New Ford 24lb injectors installed. Stock balancer was used with a spacer machined for the bolt. Rebuild has about 75000 on it, when the cam/lifter failed. Motor held normal oil pressure 42 psi after cam failed. Cam was broken in properly, because I don't believe it would of lasted that long if it wasn't.
Last edited by Cherokee Steve; February 9th, 2012 at 08:32 PM. Reason: added more description
Old February 10th, 2012, 06:13 AM   #11
Cherokee Steve
Powdercoating Guy
Morning Bump
Old February 10th, 2012, 06:49 AM   #12
cole
Need more susp travel...
cole's Avatar
How much lift with the long arm kit?
Also does it have a sye on the t-case?
cole is offline
Old February 10th, 2012, 08:04 AM   #13
Cherokee Steve
Powdercoating Guy
It's got about 5" of lift and no sye. I do have an extra frt drive shaft for when that would of been done that goes with it.
Old February 11th, 2012, 11:07 AM   #14
Cherokee Steve
Powdercoating Guy
Bump
Page generated in 0.34870 seconds with 66 queries
