03 24valve idle issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2012, 07:05 PM   #1
t buff
t buff's Avatar
Default 03 24valve idle issue
I have a 24v cummins in an 03 3500 Ram. It has a rough idle. It dosent smoke at all.
Statrs easy.
After it stumbles it recovers real fast.
It just started doing this with in the last few weeks. The idle does not rise in park anymore either. No other problems. Just a rough idle spot ANY IDEAS?
I changed the tp sensor the other day and it does the same thing. Any help would be greatly appreciated
t buff is offline   Reply With Quote
Old February 7th, 2012, 07:16 PM   #2
boggin-machine
boggin-machine's Avatar
is it a 02 or 03? completely different motors.
Old February 7th, 2012, 07:20 PM   #3
t buff
t buff's Avatar
03 thats y i put 03
Old February 7th, 2012, 07:21 PM   #4
boggin-machine
03's arent referred to as a 24v thats why i asked. thats a common rail engine. but it sounds like you have a crank sensor going out
Old February 7th, 2012, 07:30 PM   #5
t buff
t buff's Avatar
Ok. And the crank sensor would make it not idle high in park?
Old February 7th, 2012, 07:37 PM   #6
boggin-machine
crank sensors will do funny things. think about what a crank sensors job is to do. when mine was going bad i would come off the highway and it would lope till it caught its idle again around 1200 or so or till when i got back on the pedal. had a rough idle in park as well.
Old February 7th, 2012, 07:41 PM   #7
t buff
t buff's Avatar
Cool thanks for the help. If that
Old February 7th, 2012, 07:41 PM   #8
t buff
t buff's Avatar
If that dont do the trick ill let you know
Old February 7th, 2012, 07:45 PM   #9
boggin-machine
when was the last time the fuel filter was changed as well? do you keep up on your maintenance?
is it throwing any codes at all?
Old February 7th, 2012, 07:56 PM   #10
t buff
t buff's Avatar
no codes. i changed it a few weeks ago and again today
Page generated in 2.78987 seconds with 53 queries
