1988 f-150 high idle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2012, 11:41 AM   #1
78ford460
78ford460's Avatar
Default 1988 f-150 high idle
I have a 1988 f-150 with a fuel injected 302. The problem is, when it is in park and neutral the motor will idle around 1300-1500rpms cold, and when it gets warm it will idle between 1600-2000rpms. When the truck is in drive it will idle normal around 800-900rpms. Anybody got any suggestions. Thanks.
78ford460 is offline   Reply With Quote
Old February 7th, 2012, 12:04 PM   #2
94cherokeemike
IT'S A XJ THING
94cherokeemike's Avatar
Throttle position sensor had the same problem on my buddys 88 F250 and my grandpas friends 89 E150. Have you scanned the codes yet?
94cherokeemike is offline   Reply With Quote
Old February 7th, 2012, 12:28 PM   #3
Elvis13
http://oldfuelinjection.com/
This should help you check/read codes.
Old February 7th, 2012, 03:37 PM   #4
78ford460
78ford460's Avatar
I was thinking a vacuum leak or the tps. thanks for the help.
Page generated in 0.20197 seconds with 35 queries
