SOLD - 1978 Ford F-250 D44 Flat-top knuckles, already prepped for Hi-steer arms - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2006, 08:07 AM   #1
PavementPounder
PavementPounder's Avatar
Default SOLD - 1978 Ford F-250 D44 Flat-top knuckles, already prepped for Hi-steer arms
1978 Ford F-250 HP D44 knuckles. 5-stud spindle pattern. Driver's side is milled/drilled/studded from the factory as part of the OEM steering system. Passenger side recently milled/drilled/tapped by Koz - no studs. Sandblasted and available immediately. Can be transported to Dearborn for pick-up.
$125.
As of right now, I can supply the correct empty housing to go with this. It is not included. I do not have an extra set of outer hardware available at this time. I'm also waiting for someone to get back to me regarding shafts.
SOLD
PavementPounder is offline
Old October 16th, 2006, 09:49 AM   #2
PavementPounder
Hmph... Thought this shit would go fast. Then again, nobody here seems to like HP D44 fronts. :tonka:
Old October 16th, 2006, 11:53 AM   #3
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Spro, would these work on a 79 F150 axle to go high steer? What would I need for spindles then, the ones I already have with my axle? I know nothing about high steer, but know I need to address the steering of the f150 d44 going into my ZJ.
Roadhouse is offline
Old October 16th, 2006, 12:17 PM   #4
95geo
newbie
95geo's Avatar
can you run 15" wheels?
95geo is offline
Old October 16th, 2006, 12:21 PM   #5
xj4life
xj4life's Avatar
i believe you can. i cant imagine a '78 pick up running anything larger than a 15"
xj4life is offline
Old October 16th, 2006, 12:27 PM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I don't think you can clear the calipers on the half ton stuff on the 3/4 ton knuckles. Or not with out modifing them.
Jeepaholic is offline
Old October 16th, 2006, 01:17 PM   #7
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I don't want to run the 3/4 ton brakes, thats why I asked a few questions
Old October 16th, 2006, 01:32 PM   #8
PavementPounder
You need 16" rims to clear them and they require the dual-piston calipers. I did some research (along with WhiteRhino doing some) and you can't run 1/2 ton brakes on them. The contours of the knuckles are different. The flat-top's that accept 1/2-ton brakes are kind of hard to find - apparently were on the Supercabs.
Old October 16th, 2006, 02:41 PM   #9
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Thanks for the info Marc
Old October 16th, 2006, 04:24 PM   #10
amc78cj7
amc78cj7's Avatar
Are you certain you can't run Chevy caliper brackets? I thought you could. At least on the D60 dual piston conversion...
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline
Old October 16th, 2006, 06:37 PM   #11
PavementPounder
I don't know how you would run Chevy caliper brackets on Ford knuckles. The Ford knuckles have a 5-stud pattern. Don't the Chevy bracketts have a 6-hole pattern? If there's a way to do this with certain years/applications or fabbing, I just haven't seen the write-up, yet.
How come you don't want to run the big brakes, anyway?
Old October 16th, 2006, 07:38 PM   #12
95geo
newbie
95geo's Avatar
i have looked into this a long time ago too.... the knuckles dont have a scalloped cut in them to allow the caliper to be mounted closse enough to the center of the wheel to allow them to clear 15" wheels
95geo is offline
Old October 16th, 2006, 09:08 PM   #13
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Cause I alread have 15" beadlock wheels with 4.5" of backspacing......those wont clear Ford dual poiston calipers.
Old January 23rd, 2007, 10:42 AM   #14
PavementPounder
Bump.
Old January 29th, 2007, 08:16 AM   #15
PavementPounder
Sold.
Page generated in 0.58319 seconds with 68 queries
