TJ: Tub lining - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2012, 07:52 AM   #1
T_J
Make it or Break it
T_J's Avatar
Default Tub lining
I'm thinking of lining my tub with something a bit more rugged than carpet. I've heard theres spray you can get to make it similar to a truck bed. Could you guys give me a run down on what my options/prices would be?
T_J is offline   Reply With Quote
Old February 7th, 2012, 08:00 AM   #2
Bo's Cj 7
Bo's Cj 7's Avatar
I just did my glass tub with rihnoliner a gal kit was just over $100 at autozone its only been a few weeks but it looks great, it is a bit move ruff or textured then it needs to be in my opinoin but its not slippery at all. You just sand the suface a little and use a roller and brush to apply. I figured out how to do it smoother if you are interested
Bo's Cj 7 is offline   Reply With Quote
Old February 8th, 2012, 08:57 AM   #3
wally431
wally431's Avatar
I put the rihnoliner in my jeep with a steel tub, just sanded it to roughen it up a bit and put 2 coats on and it looks great. I've had it in mine for over a year now and have minimal scratches in it even with having a huge tool box in the back.
the kit i bought had the rolling right with it that was nice
wally431 is offline   Reply With Quote
Old February 8th, 2012, 09:08 AM   #4
michigan maniac
michigan maniac's Avatar
Raptor liner ... I just bought a kit, comes with a spray gun too just need a compressor, I've read a lot of reviews online bout this stuff, and I like it the best its cheap and they have a kit that you can add paint to color match if wanted here's a link http://www.tptools.com/p/2600,233_U-...Liner-Kit.html
Old February 8th, 2012, 09:24 AM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
X2 .... I did two coats and put leftover on the floor board where you're gas and brake are
H.o.r.e
Old February 8th, 2012, 11:14 AM   #6
addsmack
2009 JKU
addsmack's Avatar
Send a message via AIM to addsmack
I did herculiner on mine - did it about a year ago - no issues, looks great. Like any product you decide on, the prep work is key. You'll want to strip out everything from the interior (minus the dash). Just follow the instructions, and have some time to do it. Most kits will take 24-48 hours for the product to cure before you can re-install your seats.
addsmack is offline   Reply With Quote
Old February 8th, 2012, 05:25 PM   #7
michigan maniac
Yes prep is the key!! I decided not to use herculiner because it is not uv stable, and needs a special clear coat to make it uv stable.. while the Raptor liner is ready to go out of the can
Old February 8th, 2012, 06:29 PM   #8
joe_jeep
welfare wheeler
joe_jeep's Avatar
check out upol raptor and monstaliner. i had monsta liner in my last jeep, it was awesome!
Old February 9th, 2012, 10:40 AM   #9
T_J
Make it or Break it
T_J's Avatar
I think I'm gonna go with the rhinoliner. Thanks guys.
Old February 9th, 2012, 10:50 AM   #10
Bo's Cj 7
Bo's Cj 7's Avatar
Little trick I learned was put on first coat with roller supplied in kit just like instruction say
For second if you want smoother in spot (top of fenderwells maybe) put second coat on with brush also supplied in kit and you can still use roller on floor
I have enough to do three coats on my cj-7 out of one gal
Have plenty of beer on hand also you need to wait about an hour between coats
Tags
jeep, lining, tj, tub, wrangler
Page generated in 0.31092 seconds with 53 queries
