vortec head question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2012, 12:48 PM   #1
hoyt5885
hoyt5885's Avatar
Default vortec head question
i am in the process of building a 350 it is boored 40 over and is a 85 block i want to put vortec heads on it but beleive the heads only allow up to a 470 lift cam and i have a 488 lift cam in it and was wondering what needs to be done to the heads
hoyt5885 is offline   Reply With Quote
Old February 3rd, 2012, 12:51 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
The valve seal area needs to be machined down so the spring retainer won't hit.
Old February 3rd, 2012, 12:57 PM   #3
davidkassie
davidkassie's Avatar
an awesome set up for good torque/hp, have a set for sale if u don't already have some
davidkassie is offline   Reply With Quote
Old February 3rd, 2012, 09:47 PM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
Have the valve guide shortened and machined to accept standard valve seals (0.520 I believe). I recommend screw in studs and pushrod guides also.
Old February 3rd, 2012, 10:07 PM   #5
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
usually if you get aftermarket spring retainers they are clearanced for bigger lift cams. I am running well over .500" lift with no valve stem clearancing on the heads, i have crower spring retainers and they clear the seal no problem at full lift.
sbcrichie is offline   Reply With Quote
Page generated in 0.15835 seconds with 38 queries
