2001 trans question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 1st, 2012, 04:00 AM   #1
billycole
Default 2001 trans question
This is my wife's daily driver so i don't drive it much. I took it yesterday and noticed that after about ten miles it started to fluctuate from the normal 1500 rpms to 1800 then back down. I don't believe a band adjustment will help this because overdrive does not use the bands correct? Is a rebuild my only option and if so what is the typical cost?
billycole is offline   Reply With Quote
Old February 1st, 2012, 04:48 AM   #2
billycole
Forgot to mention i did change the fluid and filter about 3000 miles ago and the level is fine.
Old February 1st, 2012, 08:34 PM   #3
DodgeDude99
my '99 ram did this as well, replaced the throttle position sensor (TPS) and problem went away.
essentially whats happening is the torque convertor is unlocking and then locking back up.
DodgeDude99 is offline   Reply With Quote
Old February 2nd, 2012, 06:44 AM   #4
billycole
Thanks i will give it a try
Old February 5th, 2012, 06:00 PM   #5
billycole
Changed the tps and cleaned up all the grounds but still the same issue.
Page generated in 0.33437 seconds with 38 queries
