An odd plumbing question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2012, 07:41 PM   #1
Yota Bill
Default An odd plumbing question
So I went to our rental house last Saturday and replaced the bathroom vanity, sink, and faucet, but had 1 shut off valve with a very slight leak. Of course, I had the wrong shut off valves, so I couldn't change it then.
I went back tonight, shut off the water main, removed both shut off valves under the bathroom sink, installed 2 new shut off valves, reattached the hoses, and turned the main back on. Then I went back upstairs, opened both shut off valves, and everything seemed fine. Until I turned on the faucet, that is. I had no water coming out of the faucet that is only 4 days old. I removed the hoses from the faucet, and have good water flow out of both (closed the shut off's, removed the hoses from the faucet and put in a bucket, then turned the valves on) that is steady and strong.
I also noticed that with the cold water hose off of the faucet, when I opened the hot water shut off valve, water came out of the cold water inlet. I did not try that in reverse, but I would assume it would do the same thing if the hot water hose was removed from the faucet and the cold water valve was turned on.
So my question is, what would cause a new faucet to do this, after replacing the shut off valves? The water flow from the faucet was perfect before I shut off the water to replace the valves. Could it be something caused by a pocket of air that flowed through as the water was turned back on? It is a cheap faucet, fit for a rental house, but aren't they all basically the same internally?
I'm planning on just going to buy another one and install it tomorrow, but if it's a simple fix I wouldn't mind saving the time and the cash. It is a rental, after all.
Old January 31st, 2012, 07:49 PM   #2
brewchief
Some of the supply lines form the angle stop to the faucet have an built in shut off in case the supply line bursts, maybe you have this style and tripped them with an air pocket?
brewchief is offline   Reply With Quote
Old January 31st, 2012, 07:51 PM   #3
gmotox
gmotox's Avatar
Check the aerator screen on the faucet, it may just be plugged from rust and debris from changing the valves. If water came through the faucet and back out the inlet it sounds like its plugged.
Old January 31st, 2012, 07:53 PM   #4
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
that is really odd. could be something as stupid as a chunk of the rubber packing from the shutoff valve stuck in faucet. first thing and simpelist is unscrew the faucet arreator off the end of spout and see if water comes out or peices of anything in there. i will assume it is a single handle faucet since it is affecting hot and cold. next thing would be to pull off handle and packing nut and remove the ball or cart and see if anything is there and while its appart turn the water on a little to faucet and see if it come out of the holes were cart sits. if water is ther its a bad ball or cart. or just pull faucet and return it and i hope this helped some and sorry for spelling cant do that worth a crap
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old January 31st, 2012, 07:53 PM   #5
jaysusr
jaysusr's Avatar
Single faucet control? Or 2 knobs? My guess is air pocket?.....
Old January 31st, 2012, 07:54 PM   #6
jaysusr
jaysusr's Avatar
Nevr mind.... The above sound like the right track
Old January 31st, 2012, 08:00 PM   #7
Tizken
Almost every time you turn off the main you'll get a bunch of crap in the aerator on the faucet. When the pressure cycles it seems to knock it all lose from the walls of the piping.
Tizken is offline   Reply With Quote
Old January 31st, 2012, 08:04 PM   #8
Yota Bill
It is a 2 handle faucet....forgot to mention that.
I didn't take the aerator off because I only had little more then enough tools with me to change the shut off valves and didn't want to use a pipe wrench on a new fixture if it is that simple, but I really doubt it. There was a very slow trickle of water coming out, but not much. It did not act like something got stuck in the aerator.
Old January 31st, 2012, 08:05 PM   #9
Yota Bill
Also, I cant return it. My dumbass already threw the box away.
Old January 31st, 2012, 08:09 PM   #10
BlackBetty97
We Like it Loud
BlackBetty97's Avatar
Purchase a new identical faucet, install, put not working faucet in new faucet box and return.
BlackBetty97 is offline   Reply With Quote
Old January 31st, 2012, 08:32 PM   #11
DIRRTY
DIRRTY's Avatar
It may be the aerator then...if you're getting a slow trickle then you are getting water to the faucet...a lot of the aerators have a disc with a hole not much bigger than a pencil lead so it doesn't take much to clog it and as stated above when shutting off the main you always stir up debris.....Good luck and let us know how it turns out...
DIRRTY is offline   Reply With Quote
Old February 1st, 2012, 07:42 PM   #12
Yota Bill
I took the aerator off, and there was a small amount of debris. Cleaned it and re-installed, but there was little change. I couldn't waste anymore time on it, so I just bought a new faucet and installed that one. That one works fine.
I did not put the broken one in the new box and try to return it. I'll hold on to it for now, till I either decide to try to fix it or get sick of it taking up space and just pitch it.
Old February 1st, 2012, 07:50 PM   #13
firehawk
Live Action!
firehawk's Avatar
Could have solder in it from when they made it.
I had a similar incident once and another time I have a ball of solder get lodged in my kitchen faucet and could not turn the cold side water off, must have come from when we replaced the galvanized lined with copper about 10 years earlier.
Page generated in 0.26170 seconds with 61 queries
