ls engine oiling question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2012, 03:35 PM   #1
joescamaro67
joescamaro67's Avatar
Default ls engine oiling question
So my shakedown run at snofari went pretty good other than a few small things and one fairly large thing. My driveshaft is way to close to my oil filter. So when i got back i started looking int remote filter options.The problem is they are all using an adapter that is in the stock filter location.With the way my exaust is ran and the driveshaft issue I have a thought but not sure if its a good one or a bad one so here it is. I am thinking of machining a dummy filter that just alows oil to flow through where the filter should be then buy or build an adapter where the oil cooler lines would normally go and run a remote filter off those two ports Ones a feed and ones a return. Looking at the oil scematics of the engine I think its my best bet for the most clearance but what do you guys think. Looks like the oil leaves the filter and goes directly to the cooler ports so is it gonna work the same just in a diffrent spot?
ID:	88618   Click image for larger version
Name:	engine oil diagram.jpg
joescamaro67 is offline   Reply With Quote
Old January 31st, 2012, 03:51 PM   #2
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Interesting idea. I had to install my engine off center a little to allow room for my drive-shaft. I'd be interested to see how this works out for you.
RIP FULLSIZE4LIFE
SHARPMACHINE is online now   Reply With Quote
Old January 31st, 2012, 03:55 PM   #3
joescamaro67
Yea right now its just an idea but i think i might go start making a dummy oil filter on the lathe and see where it takes me.
Old January 31st, 2012, 06:17 PM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I'd be worried that I'd be missing a pressure relief / bypass in case the flow somehow was higher than what could go through the cooler lines / remote filter - but I've never looked at one to be sure.
@clarkstoncracker
Page generated in 0.29116 seconds with 36 queries
