lt1 camaro overheat and now wont start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2012, 10:13 AM   #1
93xj4dr
93xj4dr's Avatar
Default lt1 camaro overheat and now wont start
I picked up a 96 camaro with the lt1 and 6 speed saturday and it overheated on the way home. I got it cooled down but now it doesnt wanna start. Itll start with the pedal to the floor and rev to about 2500 rpms and die in about 3 seconds. Ive heard the optispark ignition systems on these are junk at best and im wondering if that may be the problem. Any other suggestions?
93xj4dr is offline   Reply With Quote
Old January 30th, 2012, 10:46 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
check engine light on / codes? Oil look okay?
@clarkstoncracker
Old January 30th, 2012, 12:05 PM   #3
93xj4dr
93xj4dr's Avatar
oil smells burnt but no antifreeze or anything in it so im pretty sure (hope to hell) the engine wasnt hurt. I didnt notice a check engine light but ill have to check for it and find a code reader. somebody told me the water pump probably went out and dumped water on the distributor. I havent had a chance to look at the car as its sitting pretty much where it died saturday.
Old January 30th, 2012, 01:01 PM   #4
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
that would be my guess as to the no start thing my 97 hit and miss did that when my dist went bad. as for the over heat dose yours have the aluminum head's if it dose id be leary of them being warped
beaterk5 is offline   Reply With Quote
Old January 30th, 2012, 02:34 PM   #5
93xj4dr
93xj4dr's Avatar
yea its got aluminum heads. Im really hoping they didnt warp but im not sure. Like i said i checked the oil and antifreeze and theyre both in their own places, not mixed together. So i can only assume the heads are ok. Im hoping to get out and look at the car tonite. Maybe do a compression test and make sure a gasket didnt go. I dont really know enough about these engines to say either way so hopefully i have some decent news before i go home tonight. IF the heads and the rest of the engine are good can anybody point me in the right direction for a good distributor? Is aftermarket a better option/ worth the money? Or should i just buy OEM? Guess ill be bending over for either one... I just want it to hurt less. lol
Old January 30th, 2012, 02:43 PM   #6
2000_WJ
2000_WJ's Avatar
Buy an OEM unit. MSD, Accel make them but dont waste your money just get the OE 96-97 vented opti.
2000_WJ is offline   Reply With Quote
Old January 30th, 2012, 03:07 PM   #7
93xj4dr
93xj4dr's Avatar
alright. Ill check everything else out and hit up auto zone after work. Hopefully ill be cruising home tonite. Thanks guys.
Old January 31st, 2012, 07:04 PM   #8
in2deep
Hole tester
i would avoid reman opti i never had one last more that 11 months before the bearing went in it, droped the green for a new one have not had a problem i do like the msd caps, fyi dont touch the little wheel on the new opti
Old January 31st, 2012, 10:07 PM   #9
skife
skife's Avatar
x2 on waterpump taking a shit and killing the opti...
speaking of wich, i've got to do a waterpump on the blazer before the dunes open :\
Old February 1st, 2012, 07:37 AM   #10
I suck cocks. Lots of them.
locally famous
you just bought it, and were coming home? that sucks
Old February 2nd, 2012, 07:22 PM   #11
93xj4dr
93xj4dr's Avatar
Yea just picked it up got 10 miles max n it died. I got it running today. To put bluntly, the top end is frapped it smokes like a chimney n pours antifreeze out the pipes. Looks like I'm building an lt1
Old February 2nd, 2012, 07:26 PM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Sorry to hear that.
@clarkstoncracker
Old February 2nd, 2012, 08:01 PM   #13
93xj4dr
93xj4dr's Avatar
O well. It happens. I may as well do some head work to it and a cam and headers. Maybe a bored tb and just make it faster. Could be a blessing in disguise I suppose.
Old February 2nd, 2012, 08:03 PM   #14
firehawk
Live Action!
firehawk's Avatar
When you buy a new or used car always take it for a decently lengthy test drive before you sign the papers even if it has a warranty.
Or this can happen to you.
Old February 3rd, 2012, 10:14 PM   #15
93xj4dr
93xj4dr's Avatar
Thats what sucks the most about it though. I test drove it for a good few miles and it did fine. Just bad luck I guess.
Old February 10th, 2012, 08:36 PM   #16
skife
skife's Avatar
probably not the best idea to build an LT1
for what you'll have into the LT1 you can swap in a 5.3 and be way ahead on your game
Old February 14th, 2012, 03:08 PM   #17
93xj4dr
93xj4dr's Avatar
yea i decided to go the cheapskate route and get the heads done and do headers/eshaust and cold air intake and call it a day. It was pretty fast stock and tearing it apart revealed alot of other performance killing problems. After fixing the flaws and exhaust and stuff itll be at least fast enough to get me in trouble. lol
Page generated in 0.31270 seconds with 74 queries
