92fleXJ's Trailer queen - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 6th, 2012, 01:17 PM   #41
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Originally Posted by Eric99tj View Post
If you are going to spend that kind of effort and money, I would strongly suggest starting with a HP60. You will not regret it. The weight is all low and unsprung anyways. I do not want to get into a D44 vs D60 debate. It is just my 2 cents.
Also width is a factor. I dont want it that wide. I wheel at a friends alot and we are borderline fitting down the trails with standard d35.
D60 will let me run a taller gear but I'm happy with my 5.14 now. It will also give me bigger shafts. But the fact is I crawl I don't bonzi.. So once I put the crv's in shafts will never be a problem again. They rate the d35 crv's for a 44" tire. Lastly is the carrier strength. I'm going with the new arb. So for what I will have it will be as strong as it can get.
Old February 6th, 2012, 01:38 PM   #42
jerm97xj
I fixed it!!!
jerm97xj's Avatar
That thing is a beast...
jerm97xj is offline   Reply With Quote
Old February 6th, 2012, 03:54 PM   #43
92FleXj
92FleXj's Avatar
Yea.. Not playin games here...
Old February 6th, 2012, 04:01 PM   #44
92FleXj
92FleXj's Avatar
2 down 2 to go..
Old February 7th, 2012, 06:06 AM   #45
Eric99tj
Just bump it....
Eric99tj's Avatar
My understanding is that the RCV D44 shafts are rated for 40" and smaller tires. I will not even go into axle tube, ball joint and knuckle strength. I am just saying that your are spending a lot of money on an axle that is borderline for your setup. People narrow D60s all the time.
Southern Michigan Rockcrawlers
Eric99tj is offline   Reply With Quote
Old February 7th, 2012, 06:28 AM   #46
curbdog17
Mini Van
curbdog17's Avatar
40" or less in a dana 44
https://www.rcvperformance.com/store/catalog/faq.php#10
Old February 7th, 2012, 06:43 AM   #47
92FleXj
92FleXj's Avatar
If I had a v8 I could se it being a problem. I've got friends with 500hp trucks running d44s all day in the sand. Granted its more giving. It seems everyone wants to go overkill when there building something.
The main reason in going with this is I'm getting a hell of a deal on a 44 that has brand new tubes and the knuckles are not welded on yet. So I can set my pinion angle to what I want. With half the work being done already.
Old February 7th, 2012, 10:11 AM   #48
92FleXj
92FleXj's Avatar
Debating on swapping my 39.5/18/15 boggers for a set of 38.5/11/15 boggers. What do you guys think? I like the skinnys plus it will help my steering issue.
Old February 7th, 2012, 08:11 PM   #49
curbdog17
Mini Van
curbdog17's Avatar
I think thats what Fullsizeforlife is running. I know they is skinny boggers. I think he likes his.
Old February 7th, 2012, 08:24 PM   #50
92FleXj
92FleXj's Avatar
I've always had wider tires. All my buddy's with skinnys go further for some reason. the only worry I have is that they are 11" wide and with my beadlock ring welded on my rims are 10.5. Kind of worries me about airing down.
Old February 8th, 2012, 05:19 PM   #51
92FleXj
92FleXj's Avatar
Started on a set of 1/2 doors today. Got them both to this point. Going to weld 1/8 plate to the back side and rhino line them.
Not bad for a tile guy!
Old February 8th, 2012, 06:00 PM   #52
low900rr
low900rr's Avatar
Looks like a good start:thumbup:
Sent from my ADR6400L using Tapatalk
low900rr is offline   Reply With Quote
Old February 8th, 2012, 08:30 PM   #53
John D
John D's Avatar
I like it. IMO you're gonna be fine on the d44 and a reasonable foot especially with the RCVs. The ball joints are easy fix with the Synergy's and a full case locker handles the ring and pinion deflection. Only weak link left is the outers and that's fixable too, RCV will even make you a package ;)
Old February 9th, 2012, 04:24 PM   #54
92FleXj
92FleXj's Avatar
One down.... Worst job ever!!
96 more bolts to go...
Old February 9th, 2012, 05:19 PM   #55
hellspawn
hellspawn's Avatar
looks good
hellspawn is offline   Reply With Quote
Old February 10th, 2012, 10:56 AM   #56
92FleXj
92FleXj's Avatar
Originally Posted by hellspawn View Post
looks good
Thanks
Old February 10th, 2012, 10:58 AM   #57
92FleXj
92FleXj's Avatar
They were skinny
I like these tires better than the originals for sure. They fit the truck a lot better. I lost 1" in Hight but I don't think that's going to be a big deal
Old February 13th, 2012, 10:06 AM   #58
92FleXj
92FleXj's Avatar
Old April 5th, 2012, 06:51 AM   #59
92FleXj
92FleXj's Avatar
After I figured out my fuel issue and got it running rite I took it out to play for a few with only 2wd and still ha the SUPER sway bar hooked up. So I did a little rear flexin
Still has about 5" of suspension left but in 2wd couldn't make it up the berm.
So with that all out of the way it was time to yank the front axel that was broke. Pinion I was guessing..
Drained the pig.. Well attempted to.. It was Bone dry..... The guy who had it before me must have never filled it back up... Thanks dick.
Well the damage is not from that but from the u joint cap drooping and hitting the balljoint at 40 on pavement when the hubs were locked in.
Broke both inner shafts and snapped the pinion.. Dang.
This is for the guys that dispute the fact that I have 20" front fox shox..
Done... Off to advantage driveline in Jackson to get it repaired so I can keep wheeling wheel my hp is being built.
Old April 5th, 2012, 03:15 PM   #60
92FleXj
92FleXj's Avatar
Draining them down to see ware they are at and filling them back to factory recommendation and hope I can 86 the sway bar after this.
New full width hp d44 with 1/2" tube and shortened to waggy width
This one is the slow roaster that is being sent to advantage drive line as well. Getting arb, 5.14s 35spline crv shafts. Moog ball joints chev flat tops and high steer. Finnish it off with the psc dual ram. Can not wate!!
Page generated in 0.32614 seconds with 84 queries
