2000 ZR2 4x4 issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2012, 08:23 PM   #1
grose
Default 2000 ZR2 4x4 issue
4x4 was not engaging. I found the vacuum actuator boot was torn, so I replaced it. 4x4 worked fine for about a month.
Hit switch to engage 4x4 high. Hear the transfer case motor engage. Accelerate the truck and hear click click click (not quite grinding) that increases or decreases with speed. Replaced vacuum switch on tcase and then replaced all fluids (front dif, t case, transmission) That seemed to fix it for a week. Back to making noise click click clck again when in 4x4 high. making noise but not actually engaging front axles. Ideas?
grose is offline   Reply With Quote
Old January 27th, 2012, 08:42 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
heres an easy test to see where the problem lies. start it up, put it in 4x4 and jack up a front wheel and give it a spin. does it spin freely? if it spins freely look to see if the front driveshaft spins with the wheel or if it does nothing. if the driveshaft doesn't spin then the problem is in the front axle. remove the battery tray to gain access to the vacuum actuator and make sure it is pulling the cable all the way. 2 common problems i have found on these trucks is either the actuator takes a dump, or the cable gets stiff and either won't engage, or disengage the diff.
Old January 27th, 2012, 08:46 PM   #3
grose
Thanks. I replaced the vacuum actuator under the battery tray. It had a tear in the boot. The cable seemed to move freely when I moved it by hand.
Old January 27th, 2012, 09:04 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
also check all the vacuum lines between the actuator and t-case, and up to the engine. the hoses are fairly shitty rubber and can degrade over time causing a leak. my 95 had a similar issue so i had to replace all the vacuum lines for the 4x4. they crumbled apart in my hands when i took them out.
Old January 27th, 2012, 09:07 PM   #5
grose
Will do. Where did you find replacement lines?
Seems that if the vacuum lines were bad the actuator would not engage. I watched it get sucked in with my own two eyes while I was testing it. Am I right?
Old January 27th, 2012, 09:10 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
well if it had a pin hole it may not be strong enough to engage fully. without seeing the vehicle in person i can only guess at the problem. as far as replacement lines i went to AZ and bought a roll of vacuum hose and used it. 5/32 i think was the size.
Old January 27th, 2012, 09:15 PM   #7
grose
Thanks, I will test it as you suggested. I assume passenger side front tire is the one to spin?
Old January 28th, 2012, 09:07 AM   #8
Jeep_Shaun
Don't Fear The Jeeper
Jeep_Shaun's Avatar
I was having an issue with my blazer. when I bought it the guy said the 4wd was messed up and that it had 4low but nothing else. Well, It had 2 low not 4low Took it to a buddies shop, and checked into it, actuator looked fine and was engaging properly, lines were good. We replaced the switch in the t case (the one that the lines hook up to) and I was able to have 4low but no 4 high. the push buttons would flash and act weird. Bought a transfercase control module (TCCM) and an encoder motor from a member on here. Had a fun time finding the TCCM on my 1995 blazer (behind the dash under the radio) replaced that, and seemed fine in the shop, Took it out to the snow, and would not work (still had 4 low and 2wd) replaced the encoder motor and my 4wd works great now.
Jeep_Shaun is offline   Reply With Quote
Old January 28th, 2012, 12:55 PM   #9
grose
A little further diagnostc info. Will not engage when going over 10MPH. I hitht e swthch, hear the transfer case engage and then a grinding noise starts.
Under 10MPH in neutral or reverse, 4 wheel engages just fine with no issues.
No light's blinking no 4x4 code thrown.
This leads me to believe that there just might be a small vacuum leak somewhere. It might not have the power to engage the coupler at higher speeds, but lower speeds it can slide over.
What do you guys think?
Old January 28th, 2012, 01:25 PM   #10
beedle4
beedle4's Avatar
Whole system/slide collor setup is junk!.
Best best which many have done is to replace it with a like year s-series bravada shaft/tube.
This replaces the two piece spilined slide collor setup with a once piece axle shaft.
You will need the shaft/tube from a 98-01 bravada. Some RTV, and time.
Once done your front end will be enguaged all the time. You will NOT need to be rolling forward at all to get it to work. So thats a big plus.
Only mod needed for this is to remove the outter snap ring where your CV would slide onto. And you can either use a cap packed with whatever to tell the sensor shit its in 4x4. Or just remove the sensor and splice the wires together.
Other options are a popnlock manual pull line, or just pull and secure with vise grips if the slide collor is still good that is.
Also make sure you get the updated TC vac switch. When the older ones fail they will suck fluid into the hvac system that leads to the controls hiss of death. You DONT want to have this happen.
Old January 28th, 2012, 01:29 PM   #11
grose
Love the idea, but that is beyond my expertise. I did make sure I had the updated vacuum switch when I replaced that.
Old January 28th, 2012, 01:40 PM   #12
snow-turtle
Selective Hearing
snow-turtle's Avatar
The vac lines come out of the tcase , go under the pass side body . Then one up by the manfold . I had one get a hole there . When you put the lines back on the switch . you got a good seat and back on the right line . Also at the actuator , a good seat . The way I teasted the actuator . Push it in cover each hole with you fingers , it won't inflate . Go to the car wash , wash the underside (if there's dirt or put glass on) Start at the tcase and follow each line . Its a pin hole in the line or a bad seat at the end .
Here are two links for you , just to have . I have crawled all over and around , For a pin hole in a dam vac line . At times I have thought about just replaceing all the lines .
http://www.s10forum.com/forum/f220/t...thread-327817/
http://www.4x4posi-lok.com/PDFs/troubleshootguide.pdf
snow-turtle is offline   Reply With Quote
Old January 28th, 2012, 01:51 PM   #13
grose
Im not a mechanic, but does it sound like I'm on the right path? Possible vacuum leak causing weak engagement?
Old January 28th, 2012, 01:52 PM   #14
snow-turtle
Selective Hearing
x2 Whole system/slide collor setup is junk!.
Old January 28th, 2012, 02:00 PM   #15
snow-turtle
Selective Hearing
Your doing good .
When parked . You push the button . You hear it engage . But it is not in 4 wheel . Its a vac leak , or bad seat at the end on the line .
The shi*y part is crawling around finding it . And Fin with the cable set up at the actuator (lube) . Like an ebrake cable sticks when shi*s in it .
Old January 28th, 2012, 03:50 PM   #16
bdd1469
bdd
bdd1469's Avatar
A lot of times when the t-case switch gets old vacume pulls atf out of the t-case and makes the lines deterierate,along with your new vacume pod.
Also check on the drivers side near the master cylinder for a plastic vacume resovoir bottle.If your truck has one,pull the line and look for signs of atf.If the lines or resovoir are full off atf it wont pull enough to fully lock the axle.
I used to pull on the cable with vise grips while someone drives the truck a few ft,or spin the front wheels if it is jacked up.You will feel the collar lock in,take the vise grips and clamp them on the cable,so it can't slide back in.I learned that trick when I had a dz302 in a s10 blazer,the motor made almost no vacume.
Old January 28th, 2012, 07:07 PM   #17
grose
I replaced the t-case vacuum switch more as a precautionary measure. I am confident fluid did not get sucked into the vacuum hoses.
One other diagnostic note. The issue only seems to appear when I try to engage 4x4 at higher speeds. The light on the 4x4 switch turns on just fine(no blinking). Everything appears fine, except that I know the 4x4 is not engaged because I'm fishtailing. When I step on it, I hear the grinding noise, but only when I step on it. The grinding is directly related to the engine RPM's. The faster the RPM, the faster the grinding.
Old January 28th, 2012, 11:42 PM   #18
grose
Parked it and lifted the truck. Right front spins by hand. Start and engage 4x4 Hi and I cannot spin the right front. Wonder if the cable is pulling but not all of the way. Anyone know how far that cable has to pull the rod to engage the front axle?
Old January 29th, 2012, 06:45 AM   #19
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
roughly 1/2-3/4" if i remember correctly
Old January 29th, 2012, 10:17 AM   #20
bdd1469
bdd
bdd1469's Avatar
You could put a vacuum gauge on it and rev the motor,to see if you are pulling full vacuum.
You could put a vacuum pump on the actuater, to see if it will lock in and not slip that way.
You could lock the cable with vise grips and drive to see of it stays locked in.
Any off the above will help narrow down your problem.Your slip collar could be messed up from too much grinding,but you wont know untill you manually lock it and drive it hard.
I have blown up more s10 front driveshafts then I can count.When the cv joint goes out they make a huge grinding noise in 4x4,and can fool you by kinda putting power to the front wheels,untill it totally self destructs.check it.
I have owned close to a dozen s10/jimmies and built several with v8s.I know you dont think you have atf in your vacuum lines,but I never worked on an S10 that didn't,unless it was new.It only takes a few drops to deterierate rubber over time.
good luck.
Page generated in 0.44001 seconds with 83 queries
