u joint problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 24th, 2012, 09:44 PM   #1
tonkatruckon44s
tonkatruckon44s's Avatar
Default u joint problems
i have a 1989 k5 blazer with a sm465np205 combo in it but both joints on the rear driveshaft keep going out on me and this isnt wheeling its just daily driving its been about 6 in the last month idk what is wrong only 1 has been the one at the axle the transfercase one has broke 5 times is there something i am doing wrong. btw the blazer has 8 inches of suspension lift but the driveshaft angles arent that bad at all so i dont understand.
tonkatruckon44s is offline   Reply With Quote
Old January 24th, 2012, 10:10 PM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Is it held on by a strap or ubolt? If u bolt you could be over tightening it causing it to bind. Also if you blew a few ujoints your yoke is probably messed up. I fought the same thing as you and finally took a u joint and put it on the yoke, tightened it down and it bound up because the yoke was mared up and damaged. new yoke no more problems
Old January 24th, 2012, 10:29 PM   #3
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
Pic of driveshaft?
Is your shaft 'in phase'?
j-kb8ymf
kb8ymf is offline   Reply With Quote
Old January 24th, 2012, 10:53 PM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
Correct your pinion angle to compensate for the lift.
How is your front driveshaft surviving with 8 inches of lift?
Old January 24th, 2012, 10:54 PM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
Originally Posted by kb8ymf View Post
Pic of driveshaft?
j-kb8ymf
I wouldn't think it would be a two piece driveshaft considering its a 4x4.
Old January 24th, 2012, 11:12 PM   #6
kb8ymf
kb8ymf's Avatar
That's why I asked for a pic. There are plenty of two piece shafts on 4X4's
I wasn't assuming anything just yet but both yokes need to be in phase if the d'shaft has a slip joint in the shaft or it's a slip joint in the t'case.
If he's going through u-joints almost weekly there is something drastically wrong. It might be bent also.
There's always more to the story..................
j-kb8ymf
Old January 24th, 2012, 11:14 PM   #7
deerebowtie
Unchained
deerebowtie's Avatar
cardan joint rear shaft and make sure your pinion angle is good. also, what spline count on the 205 are we working with here to suggest where to rob parts
Old January 25th, 2012, 10:50 PM   #8
tonkatruckon44s
idk if you would call it a one piece or two piece shaft because the slip yoke is on the shaft like it is on a front shaft because a 205 is a non slip yoke and i believe it is either a 28 or 31 spline not qite sure but i gotta find a new yoke now because my buddy said it was a "ujoint broke" but he snaped a ear off the yoke
Old January 26th, 2012, 10:25 AM   #9
deerebowtie
Unchained
go find an np208 with the flange and cardan joint front shaft. you'll have to source the flange seal but that's only 6-9$. find a long piece of tube with the same ID, remake shaft, done.
add some trans fluid to the shaft, keep the slip at about 1-1.5" each way. weld one end at a time providing time for it to cool so you don't create a pressure vessel with the oil.
tuh dah, a 40-80$ driveshaft that solves all your problems.
Old January 26th, 2012, 10:31 AM   #10
tonkatruckon44s
i found a new yoke for 45 buck and then when i get a chance i am going to take it to the driveshaft shop and have them make me a new one
Page generated in 0.21953 seconds with 53 queries
