Waggy/M715 truggy - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 24th, 2012, 07:18 PM   #1
MidMichFSJ
MidMichFSJ's Avatar
Default Waggy/M715 truggy
Well, starting with what's left of my 89 grand wagoneer, chassis specs are 7" spring over/ shackle flip, 3" spring lift, and 1" shackle lift. Axles are Dana 44 front and rear, 3.73 open front ARB rear. drivetrain is AMC 401 mildly built, about 400 horse, TF 727 with a shift kit, and a NP 229 to finish it out.
I bought a 67 M715 about a year ago, shortly after I rolled the waggy, with intentions of using the cab and front clip on my chassis. Sent the body out to sandblast recently and patched the holes in the floorboards and a few other places. Next was the rockers, a little rock protection should come from the 4"x6"x1/4 wall tubing I welded in.
I machined some body mount bushings out of aluminum since the rockers will be tied in to the frame and Exo-cage later.
Set the cab today and hooked up brakes and steering, before putting on the front clip. Should be more to come soon.
ID:	88281   Click image for larger version
ID:	88282   Click image for larger version
ID:	88283   Click image for larger version
ID:	88284   Click image for larger version
ID:	88286   Click image for larger version
MidMichFSJ is offline   Reply With Quote
Old January 24th, 2012, 07:24 PM   #2
bono
bono's Avatar
subscribed, this should be awesome
bono is offline   Reply With Quote
Old January 24th, 2012, 07:29 PM   #3
XJsport95
Haters be my motivators!!
XJsport95's Avatar
X2 on the subscription. Gonna be an awesome build. You should definitely go with a sweet looking gladiator grill to top this sweet build off. Also on another note, where did you get that front bumper thats on it now???
XJsport95 is offline   Reply With Quote
Old January 24th, 2012, 08:19 PM   #4
MidMichFSJ
MidMichFSJ's Avatar
Bumper came from BJ's Offroad. I really want to find I rhino grill, but they're not easy to come by.
Old January 25th, 2012, 03:47 PM   #5
MidMichFSJ
MidMichFSJ's Avatar
Got the dash in today and buttoned up some wiring under the hood. Ordered a throttle cable and made a parts list for the electrical in the cab.
Old January 25th, 2012, 03:51 PM   #6
gladiator18
66' Gladiator
gladiator18's Avatar
Subscribed! This should be a fun build!
gladiator18 is offline   Reply With Quote
Old January 26th, 2012, 12:26 PM   #7
mboies
BS MUDDERZ
mboies's Avatar
Looking good so far.
mboies is offline   Reply With Quote
Old January 26th, 2012, 04:27 PM   #8
MidMichFSJ
MidMichFSJ's Avatar
Took about 8" off the back of the frame today, welded the old trailer hitch in as a rear crossmember/tow point. It will stay this way until I four link it a few years from now. Should be able to shorten the frame more then. Also took out the crossmember right behind the cab, this will be replaced with something more custom once I decide on positioning of the fuel cell and compressed air tank.
ID:	88358   Click image for larger version
Old January 26th, 2012, 05:48 PM   #9
MidMichFord
The Spawn of Ironman
MidMichFord's Avatar
Hopefully that damn dog chews on this instead of my HARLEY!!!!
MidMichFord is offline   Reply With Quote
Old January 26th, 2012, 06:16 PM   #10
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Nice! (subscribed) I'd love to find an M715 tub & front clip someday.
Craig
Old January 27th, 2012, 04:51 AM   #11
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Nice...I was going to mention that you should think about stretching the wheelbase a bit when I first read this, but I see now you chopped the frame. Having seen a J-truck cabbed Waggy before....they look a little short.
Now that I look at the pics, looks like this treasure had it's leafs moved forward quite a bit...perhaps Cornfed will chime in about it.
Old January 27th, 2012, 08:43 AM   #12
Offroadian
seasoned
Subscribed
Offroadian is offline   Reply With Quote
Old January 27th, 2012, 08:55 AM   #13
mschaffer66
mschaffer66's Avatar
Interesting...
M715's have always made me drool.
Old January 27th, 2012, 08:56 AM   #14
tweak
Are we there yet?
tweak's Avatar
Awesome Kyle! Glad to see it start to come together. What are you thinking about doing for the area behind the cab?
Old January 27th, 2012, 11:20 AM   #15
MidMichFSJ
MidMichFSJ's Avatar
Wheelbase on it right now is 108" I believe, I'm going to leave it there for now. In the future when it gets tons and linked I may stretch the front out a bit. Out back is going to consist of a 16 gallon oba tank, fuel cell, storage box, and cage.
Old January 30th, 2012, 05:41 PM   #16
MidMichFSJ
MidMichFSJ's Avatar
Got a bunch of wiring under the dash buttoned up today. Gauges showed up, should have pics tomorrow. Ordered a fuel cell also.
Old January 30th, 2012, 07:05 PM   #17
danimal
IS IT JEEPIN TIME
danimal's Avatar
Subscribed:thumbup:
Sent from my LS670 using Tapatalk
danimal is offline   Reply With Quote
Old January 31st, 2012, 06:16 PM   #18
MidMichFSJ
MidMichFSJ's Avatar
Gauges and switch panel are in and wired. Just need to mount and wire the tach and all the wiring in the cab will be done.
Old February 12th, 2012, 06:22 PM   #19
MidMichFSJ
MidMichFSJ's Avatar
Tach is in and wired. Fuel cell is mounted and sending unit is wired. Need to finish plumbing the cell and build a battery tray/cables before it will run
Old February 15th, 2012, 04:41 PM   #20
MidMichFSJ
MidMichFSJ's Avatar
Battery tray is in and cables are installed. Fuel cell is plumbed, it runs. And all the wiring is right. Also got the top frame on.
ID:	89266   Click image for larger version
ID:	89267   Click image for larger version
Page generated in 0.40763 seconds with 84 queries
