Front axle on Ram - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 2nd, 2006, 06:58 PM   #1
DodgeitRamit
DodgeitRamit's Avatar
Default Front axle on Ram
Hey guys just wondering what your input is on this. I got a 96 Ram 1500(Coil spring setup) lookin to put something stronger up front, or at least go 8 lug since i am goin 8 lug rear. I was wondering whats the best way to go. Now if I got a Dodge 3/4 or 1 ton front are my control arms gonna bolt up? Driveshaft, etc? What other fab work will have to be done and is there anyone who has already done this on a Ram whats the best way to go? Also thinkin about old ford or dodge D60 up front but seems like a ton of work to swap all of the mounts over and prolly have lots of other issues. Any input is appreciated
DodgeitRamit is offline   Reply With Quote
Old October 2nd, 2006, 09:21 PM   #2
PavementPounder
PavementPounder's Avatar
Strongest setup would be the Ford high-pinion D60. This would also allow you to avoid unit bearings, not have a center-axle disconnect, and also run lockouts, but you will have to fab all the mounts & brackets. Most compatible setup would be a Ram low-pinion D60 (bolt in). 1999-up have the better brake setup. 98-down has the rotor pressed on the hub. The later ones have the removeable rotor. The 8800lb front D60 found in 2500's is the same as a 3500 front, but without the dually crap. That's the one you want if you want to bolt it in.
Old October 6th, 2006, 05:59 PM   #3
sonic
sonic's Avatar
I think I may just know someone who has some new 1 tons for sale. Now who was that again?
sonic is offline   Reply With Quote
Old October 6th, 2006, 08:31 PM   #4
DodgeitRamit
Haha yeahh I've been dreamin about those for a few weeks but they are a lil to costly for me ..... but maybe if you give me an appealing price on that front axle maybe we could make a deal.
Old October 8th, 2006, 10:28 PM   #5
busyfixin
Balls Deep
busyfixin's Avatar
pp, my dads 99 has the pressed style rotors, maybe it was later that they switched? yea, the late 80's ford high pinion D-60 is your best bet. not cheap though. dodge didnt have the diff on the drivers side till 94, when they went to the unit bearing/disconnect style, so you wont find one from a dodge that will work, unless you accept the unitbearing/disconnect.
Page generated in 0.16628 seconds with 39 queries
