8.8 in yj help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2012, 12:33 PM   #1
hoyt5885
hoyt5885's Avatar
Default 8.8 in yj help
i am looking for any type of help to put 8.8 in yj what are some measurements for where to mount the perches and shock mounts thanks
hoyt5885 is offline   Reply With Quote
Old January 22nd, 2012, 12:43 PM   #2
jeepnxj96
jeepnxj96's Avatar
use your old axle for reference
Old January 22nd, 2012, 01:47 PM   #3
hoyt5885
hoyt5885's Avatar
where off the old axle would i measure from
Old January 22nd, 2012, 02:00 PM   #4
low900rr
low900rr's Avatar
You need more than that....you gotta set you pinion angle right too. Why are the perches off the stock axle?
Sent from my ADR6400L using Tapatalk
low900rr is offline   Reply With Quote
Old January 22nd, 2012, 02:06 PM   #5
hoyt5885
hoyt5885's Avatar
i know u have to set pinon angle but u have to move the perches for the 8.8 because it is narrower. and where are u guys mounting the shock tabs to on the axle
Old January 22nd, 2012, 04:19 PM   #6
low900rr
low900rr's Avatar
If you got fab skills start cutting and welding. If your leafs are on the jeep measure from center pin to center pin. Take that measurement and get it centered up on the axle. The 8.8 pinion will be offset to one side. You could also measure the frame for center. Outside to inside for perfect center.
Old January 22nd, 2012, 04:31 PM   #7
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I found bolting a flat steel bar to a stud on both ends helped in getting accurate measurements. Then find your center of axle. Mark it in paint. Measure center pin to center pin on leaf springs while installed on jeep. Measure and divide by 2. Go over this many inches from center mark on axle. Tach weld perches. Install and check centering again.
Old January 22nd, 2012, 05:53 PM   #8
jeepnxj96
jeepnxj96's Avatar
I weld the shock tabs on the centerline of the axle tube as well, so they don't hang down below the tube. And follow the advise above for spring perch width.
IIRC the width is right around 45" from center pin/center pin, maybe a touch less
Old January 22nd, 2012, 06:53 PM   #9
hoyt5885
hoyt5885's Avatar
ok do i need to use the upper shock relocating brackets and this is for sua
Old January 22nd, 2012, 07:07 PM   #10
Nvrenuf
Nvrenuf's Avatar
You can use the stock upper shock mounts. Be careful moving the lowers up to high if you want to reuse your existing shocks.
Old January 22nd, 2012, 07:38 PM   #11
hoyt5885
hoyt5885's Avatar
where would i mount the shock mounts
Old January 22nd, 2012, 08:07 PM   #12
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
just get out there and use a tape measure....... there is no SET standard as everyone does it differently. I would get the axle in first than worry about the other stuff.... once its in you will see where it needs to go.
Old January 22nd, 2012, 08:52 PM   #13
low900rr
low900rr's Avatar
What he said!!
Old January 23rd, 2012, 07:08 AM   #14
Tab
Tab's Avatar
Are you sure you're ready for this project?
Old January 23rd, 2012, 10:34 AM   #15
hoyt5885
hoyt5885's Avatar
i am ready i did a 400sbc in my yj just trying to figure what i need and get all the tips i can
Old January 23rd, 2012, 10:43 AM   #16
Did anyone give you measurements on the motor mounts for your SBC or did you drop it in and start figuring out what you need? What you are asking is pretty tough to give answers on. Either you buy a complete kit or you set it in place and start measuring.
Old January 23rd, 2012, 10:56 AM   #17
Spring perches: Take your old axle and measure where they are, then thats where to put them on your new axle
Pinion angle: Mark your axle where the perches need to be, set the perches there without welding them. loosely bolt in the u-bolts so the axle is in place, but you can rotate it. put the Jeep on the ground and get the axle rotation where you need it (depends on if you are running a CV or standard u joint)
Shocks: put them wherever you want them. Everyone has their preferences.
Old January 23rd, 2012, 11:20 AM   #18
All5ofus
All5ofus's Avatar
I worked off the brakes backing plates. Just compensate for the minute difference.
This is one of the most talked about swaps. Just Google search and you'll find tons of info on it.
All5ofus is offline   Reply With Quote
Old January 23rd, 2012, 11:24 AM   #19
kickstand
circling the drain
kickstand's Avatar
me thinks not so much
Old January 23rd, 2012, 11:25 AM   #20
michjeeper
97 Sahara TJ
michjeeper's Avatar
This will help. http://www.jedi.com/obiwan/jeep/ford88.html
michjeeper is offline   Reply With Quote
Page generated in 0.28731 seconds with 83 queries
