22RE problems - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2013, 01:32 PM   #41
Suta99
Suta99's Avatar
I have 2 22r's a 22re and a 20r all run great with little to no maintenance. Some go months between running and fire right up.
Old March 6th, 2013, 09:06 AM   #42
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I'm a Toyota guy but not a 22re fan by any means.....they are not great motors
Old March 12th, 2013, 01:22 PM   #43
J/T
J/T's Avatar
Send a message via Yahoo to J/T
Check the air flow meter, mine did the same thing for a while. I pulled the meter apart and adjusted it, and it fixed it, the springs wear out and so does the sensor on top. the motors are great, just stupid electronics.
J/T is offline   Reply With Quote
Old March 12th, 2013, 10:46 PM   #44
tgmaul
tgmaul's Avatar
i agree things get wear. duh 22re are GREAT motors id trust life with one in front of me : ) not super power but ok power, thats all i need.
toyotas rock its to bad michigan had such a bad taste of these trucks, only bad taste was the shitty government road crew spraying salt all over the roads.
salt belt sucks anyway you cut it.
tgmaul is offline   Reply With Quote
Old October 14th, 2013, 08:48 PM   #45
Hooperdog
OllllO
Hooperdog's Avatar
I just bought the one on here with 51k miles on it, been sitting for about 10 years they said. put a battery in it and gas and it started right up.. then changed the fuel pump a fuel line and flushed the tank. I think I need a new tank, andsending unit,have to find one, probably going to do the plugs cap/rotor too, it runs good but idles low like 500 rpms. shouldn't it idle about 850rpm? it's a 1994 22r, might be re have to look. Anything else I should check .. oh ya changed the oil first thing forgot to say that. Can't find the fuel filter though, where is it at?
Hooperdog is offline   Reply With Quote
Old October 14th, 2013, 09:37 PM   #46
Hooperdog
OllllO
Hooperdog's Avatar
I found the fuel filter by the starter, also see it's a 22RE motor in it.
Any recommendations for shocks?
Old October 15th, 2013, 12:34 AM   #47
Rattler
Home Sweet Homicide
Rattler's Avatar
My 22RE ran with almost all the electrodes burned off. It was starting to lose power going up hill. I was amazed it ran like it did.
Bilstein 5100s on my Tacoma and I love them!
Old October 23rd, 2013, 07:25 PM   #48
Hooperdog
OllllO
Hooperdog's Avatar
still looking for shocks, got the new filter on and the new tank in, she runs good.
Old September 18th, 2015, 07:55 PM   #49
Baookamn
I had a 22re do this to me and it was because there was an air leak after the MAF.... which meant it was sucking unmetered air into the throttle body.... the MAF directed the ECU to only give the fuel it thought it needed.
What happened was the intake pipe somehow landed on the power steering pulley and burnt a hole in it. once i fixed the leak it ran mint.
Try holding the flap inside the MAF wide open and manually pull on the throttle... if it runs mint you have an unmetered air problem.
Baookamn is offline   Reply With Quote
Page generated in 0.25913 seconds with 50 queries
