22RE problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2012, 02:28 AM   #1
alaska907
Default 22RE problems
i have a 22RE an when i start it up it runs good but when i start reving it up to about 2000 rmp it starts running like crap it wants to die but if i jest keep reving it up it will clear up about 3500 4000 rpm i replaced the throdale position sencer in it an it seamed to help out a little bit but not much any ideas anyone
alaska907 is offline   Reply With Quote
Old January 22nd, 2012, 06:02 PM   #2
Bad_Vision
Bad_Vision's Avatar
Fuel filter or flow issue?
Check engine light?
Bad_Vision is offline   Reply With Quote
Old January 23rd, 2012, 02:00 AM   #3
alaska907
no check engine light on
Old January 23rd, 2012, 02:15 AM   #4
Bad_Vision
Bad_Vision's Avatar
well start with the basics
Spark wires
spark plugs
fuel filter
fuel pressure before and after fuel injectors
engine timing
exhaust flow (clogged Catalytic converter or muffler)
Old January 23rd, 2012, 10:53 PM   #5
alaska907
brand new cap rotor spark plugs and wires cat and muffler are all good jest put in a new TPS an still nothing
Old January 23rd, 2012, 11:02 PM   #6
Toyfish
Toyfish's Avatar
check the radiator for bubbles while its running sounds like it may be a head gasket starting to go my 3.0 runner did that nevr heard of a 22re doing it but its something to look for
Old January 23rd, 2012, 11:10 PM   #7
alaska907
no bubles that i can see i hooked my block tester up to it an it dident come back with nothing
Old January 24th, 2012, 09:25 AM   #8
Bad_Vision
Bad_Vision's Avatar
fuel pressure
fuel filter
Old January 25th, 2012, 04:14 PM   #9
joslovandikai
joslovandikai's Avatar
This is your problem. A 22re without a check engine light on is bad news.
But in all seriousness check your timing. My last 22re did all sorts of goofy stuff. Turns out timing was WAY off.
joslovandikai is offline   Reply With Quote
Old January 25th, 2012, 06:00 PM   #10
Toyfish
Toyfish's Avatar
yea if no bubbles i agree with check timing
Old January 25th, 2012, 06:56 PM   #11
firehawk
Live Action!
firehawk's Avatar
I expected to see Kickstart reply in here
Old January 27th, 2012, 01:02 AM   #12
alaska907
i put a new distributor on it an it helped some but still not all there
Old January 27th, 2012, 03:38 AM   #13
snow-turtle
Selective Hearing
snow-turtle's Avatar
The spark plugs . Were they pregaped or did you gap them ?
x2 check the timing
? o2 sensor , is there one . That will tell the computer its is running rich , lean .
cap or rotor , are they on right . not broken
You put spark plug wires on . Are they put on , in the fireing order . Are they all the way on , dis cap and spark plug .
Did they give you the right parts at the store , for that motor ?
snow-turtle is offline   Reply With Quote
Old January 27th, 2012, 07:38 AM   #14
alaska907
yup all plugs where gaped properly timing was put to manufacturing specs new cap rotor an 02 sencer and new plug wire and yes they on on corectly
Old January 27th, 2012, 02:39 PM   #15
kickstand
circling the drain
kickstand's Avatar
22re's are junk
There, I did it, you happy firehawk jay?
Check the ignition module ignitor thingy, mine was shit and the truck idled like shit but ran ok under load.
Timing could be off, timing guides and timing chain replaced recently?
My 22re had all loads of issues, then it blowed up, rebuilt it, new ignition thingy, new pistons, rings, bearings, cam, etc. ran decent after that, until it died on the way home for the new owner, fucking peices of shit.
Old January 27th, 2012, 04:35 PM   #16
firehawk
Live Action!
firehawk's Avatar
22re's are junk
I have heard this story about a million times.
The 3 22r/re's I had I only replaced a radiator and a thermostat.
You suck
Old January 27th, 2012, 08:01 PM   #17
kickstand
circling the drain
kickstand's Avatar
Only car/truck I've ever had major/multiple problems with that weren't self inflicted.
Old January 27th, 2012, 09:26 PM   #18
alaska907
i havent checked the ignition modual yet is there away to do an olms test on them by chance????
Old January 28th, 2012, 11:58 PM   #19
alaska907
im starting to think its a grounding issue
Old January 29th, 2012, 11:38 AM   #20
kickstand
circling the drain
kickstand's Avatar
I can't answer that for you. I haven't fucked with one of those peices of shit in 8 years.
If you have a haynes manual it should outline how to trouble shoot it, I will look to see if I still have mine, but its much more likely that I don't/
Page generated in 0.32947 seconds with 83 queries
