TTB Limited Slip ???'s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2012, 02:23 AM   #1
Bruno2
Default TTB Limited Slip ???'s
I have a 87 Bronco. I was wanting to install a factory LS carrier into the front rear end. I keep hearing stuff like "You have to machine one of the side gears down to allow the passenger axle shaft to slip in far enough to get the e clip on it" or "I have to use a spring in between the slip and stub on the passenger side axle to push it into the diff or it wil slde out". At some time Ford put a few LS front carriers into trucks. If any of what I am being told is true then how did Ford get the axles to stay in?
Bruno2 is offline   Reply With Quote
Old January 22nd, 2012, 10:06 PM   #2
deathbypsi
Brian R.
deathbypsi's Avatar
Just to be clear are you talking full size bronco or bronco2?
Page generated in 0.20036 seconds with 29 queries
