96 Chevy Idles fine but Dies out when acceleratin - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2012, 06:08 PM   #1
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Default 96 Chevy Idles fine but Dies out when acceleratin
So my truck just started doing this about 3 hours ago. I went sled riding around some trails (pulled 2 sleds on a trailer), didn't really do anything different, just a little 4-wheel drive and a little heavy on the gas (extremely shitty tires). Everything was just fine till i literally started to turn into my driveway. My truck all of a sudden died out, just flat died, no sputtering/spitting; just gone.
I did have the boom boom on but that was it. I put it in park and tried to start it again, it turned over hard like the battery was low on juice, but it idled just fine. I put it in gear and went to continue and it died again, did that about 4-5 times just trying to drive it up a 50ft driveway. The only thing i noticed was that when i left it sit for a minute or two after it died one time it started up normal (no hard starting), it has always seemed to start a little rough, as in the battery always seems to be a little low (it'll turn over, hesitate for a second then start right up)
The only known problems it has are the drivers ball joints are completely gone and the thermostat is stuck open; both of which are getting replaced tomorrow (sunday 1/22). It has always ran cold (the gauge never got up to 200/210) always stayed around 160-180 (i know, needs a new t-stat)
I haven't exactly given it a full once over, i put it on the scanner and the scanner didn't show any DTCs, and basically said F-it till tomorrow. The only things me and the gramps can come up with is the computer (don't know what exactally), the TPS, or i've read online that a similar problem was solved with a new coolant temp senser
Any idea or fixes for this problem?
Old January 21st, 2012, 06:10 PM   #2
wave_crusher
I'll Direc your TV
Oh I forgot that one of the times it died, it kinda died, came back a bit, died out, came back then gone completly. My foot on the gas didn't seem to do anything other rev it up when it started to come back
Old January 21st, 2012, 06:27 PM   #3
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
I had a pontiac that did this and it turned out to be the battery being bad. I got a new battery and no more problem. I would check the volts on the battery and start it and check again to see what the alternator is putting out.
With my Pontiac the alternator went out so i replaced it and then it must have weakened the battery because that was when i started having problems like yours. Funny thing was the battery checked good under a load test but caused the same issue when put into another car.
tctrojan17 is offline   Reply With Quote
Old January 21st, 2012, 09:10 PM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
My guess is that you have a weak battery and a bad fuel pump.
Old January 22nd, 2012, 03:42 PM   #5
wave_crusher
I'll Direc your TV
Battery tested good, at least according to the experts at advance auto....i changed the fuel pump (whole sending unit) last year.
I believe my alternator is not putting out the right amps, i'll take it in and have it tested to see. I changed the t-stat, and coolant temp sensor and it seems to be just fine now...huge difference in how hot the heat is
Old January 23rd, 2012, 11:47 AM   #6
tonkatruckon44s
tonkatruckon44s's Avatar
what kind of fuel pump did you put in it because i know that the airtex 1 year warranty fuel pump from advanced are not the best every company has its bad parts and the airtex pump is a bad part we get they are just built cheaply for the chevys it seems. i always would go with either delphi or bosch fuel pump advanced also can test your altenator for you. yes i do work there but i am not afraid to admit the faults of the company
tonkatruckon44s is offline   Reply With Quote
Old January 23rd, 2012, 11:58 AM   #7
jerm97xj
I fixed it!!!
jerm97xj's Avatar
^^^^^ Reading that made my head hurt. ^^^^^
jerm97xj is offline   Reply With Quote
Old January 23rd, 2012, 12:04 PM   #8
tonkatruckon44s
sorry i posted that in the middle of doing my homework for college and was all over the place but fixed it now
Old January 23rd, 2012, 12:08 PM   #9
jerm97xj
I fixed it!!!
jerm97xj's Avatar
Oh yeah, Thats much better lol. I have terrible grammer and spelling. I'm just messing with ya.
Old January 23rd, 2012, 12:26 PM   #10
tonkatruckon44s
Old January 24th, 2012, 01:49 AM   #11
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
If your alternator checks out good i would strongly consider finding a battery you can bum for a day and see if that is the case. Like i said, mine tested good at advance but it did the same thing in two different cars after words.
Old January 24th, 2012, 05:08 PM   #12
wave_crusher
I'll Direc your TV
It hasn't done it since i replaced the t-stat and for giggles i replaced the coolant temp sensor too. I still need to get the alt tested...either was i would like to get a higher amp one
It was a delphi pump i believe, it wasnt from advance, i got it from rockauto.com, love that site. I got the whole sending unit, not just the pump. I like advance for regular parts, but electronic stuff and fuel pumps i go with something a little more reliable
Page generated in 0.47366 seconds with 59 queries
