Ford 9 inch axle bearing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2012, 12:44 PM   #1
jball
Default Ford 9 inch axle bearing
I have the 3/8" stud 9" axle end caps. There is a lot of load on the seal to get it to where it is at in the picture, there is about 3/16" gap and I do not want to tighten it up anymore, for fear of ruining it. The outer bearing seal does not fit into the cap. Should it fit into it? I can not find the old ones, I started this a long time ago and am finally starting to make some progress. This is a SET 20 timken bearing set. Is there a different seal for the smaller stud housing? Do I have to buy different caps?
I got this axle from a junkyard, do not know the specific year it came from. I'm thinking it's from a Bronco, because it was the narrowest one they had. Both axle shafts are the same length, 31 spline.
Any thoughts?
jball is offline   Reply With Quote
Old January 21st, 2012, 12:48 PM   #2
Nuggets
I fix stuff!
Nuggets's Avatar
You are crushinig the seal because you don't have the drum break backing plate installed. You will have to make a spacer the thickness of the backing plate material.
Old January 21st, 2012, 03:06 PM   #3
jball
Correct! Thanks, forgot all about that. Easy fix... thank you so much.
Old January 21st, 2012, 09:52 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
also you are missing the "wedding" ring that is pressed on to hold the bearing put.
Old January 21st, 2012, 10:18 PM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
Good eye, I didn't catch that.
Old January 22nd, 2012, 08:35 AM   #6
jball
Yeah, I was making sure everything fit right before I put those on... and also for the wife to be out of the house to use the stove to heat them up.
Thanks again.
Old January 22nd, 2012, 10:34 AM   #7
Nuggets
I fix stuff!
Nuggets's Avatar
Thanks again.
If you were closer, I'd press them for you.
Old January 25th, 2012, 08:23 PM   #8
jball
Thanks for the offer, but I got them on, got a truss drawn up and ordered as well as caliper brackets... should be done with this someday soon. GL4x4 rocks.
Tags
ford 9 inch, set 20
Page generated in 0.27134 seconds with 47 queries
