Need Trans/T-case info/help... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2012, 07:19 PM   #1
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Default Need Trans/T-case info/help...
What I have...
350 SBC/TH350/(Drivers drop)NP231C with a Terraflex Supershort SYE and stock 30/35 axles..
What I am putting under it...
Chromo'd Scout Dana 44's (Pass Drop)...
I need to know what is going to be the least expensive way of attaching a Pass drop t-case on my TH350 (has a 4bolt to 5 bolt adapter in between both cases presently)
As of right now I have a line on a two 205's with adapters for close to 200 bones each, but they are in the other end of Michigan...
I have searched a couple of sites, this one fairly extensively and am getting confused
Thanks for the help
Old January 19th, 2012, 07:49 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
if memeory serves me right and it has been a while doing it, you will need a 700r4 to 231 adapter out of a s-10 and get a 2" aluminum spacer to go between the t350 and the adapter. And then you will need to have a short 2wd shaft installed into your trans. With all that it will be a looong drivetrain in a jeep.
reread your post and you have a drivers drop t-case and a pass drop front axle that combo will never work together.
Old January 19th, 2012, 07:50 PM   #3
KILLER"B"468
Yankabilly
cheapest route is the 205 and use the 205 adapter for a t350
Old January 19th, 2012, 07:51 PM   #4
KILLER"B"468
Yankabilly
the most cheapest way is to find someone who is giving away a np203 but it is bulky as hell
Old January 19th, 2012, 08:20 PM   #5
BigBird
BigBird's Avatar
You must have missed when I said I was looking for Pass drop case options...
And that was what i was thinking...
Thanks a bunch Killer"B"... I appreciate your help... I was actually hoping you'd chime in as most of the posts I found when I searched had your posts in them...
Jamie
Old January 19th, 2012, 08:41 PM   #6
KILLER"B"468
Yankabilly
No problem, just not on here as much anymore. My boys keep me busy with baseball.
Old January 20th, 2012, 03:46 PM   #7
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Find a NP 208 passenger drop. They put them on th350s here and there. Better low range and ALOT lighter aluminum case.
Page generated in 0.30432 seconds with 44 queries
