2000 chevy zr2 s-10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2012, 08:41 AM   #1
02ZR2
Smoke Eater 11
02ZR2's Avatar
Default 2000 chevy zr2 s-10
Does the truck have a negitive or positive switched head light system? Thanks
02ZR2 is offline   Reply With Quote
Old January 19th, 2012, 07:41 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
just about every electrical circuit in a vehicle i can think of is switched power not switched ground. so yes your headlights are switched power. there are very few switched ground circuits in a vehicle, mainly because if the circuit is hot all the time, and something causes a short you could end up with a fire very easily if the circuit isn't fused in the right place.
Old January 19th, 2012, 09:16 PM   #3
Medic8
You call, we haul.
Medic8's Avatar
Actually... wrong. A good majority of the time, if something is controlled by the PCM, it's switched by ground, not by power. Examples would be your fuel injectors. One pin is VPWR which is a constant 12v, and the SIG line, which is routed to the PCM and is a controlled ground side. I realize the headlight switch isn't controlled by the PCM, but I was just using that as an example.
ANYWAYS, topic-at-hand; I'm assuming you're looking for a wig-wag relay setup for your ZR2 or some sort of headlight flasher? It's not a direct wire, but yours is ground side switched.
http://www.galls.com/documents/S-10J...zer_Sonoma.pdf
That has the wiring diagram.
Old January 20th, 2012, 08:54 AM   #4
02ZR2
Smoke Eater 11
02ZR2's Avatar
Thanks guys.. And yes Medic8 im a firefighter/First responder tryin to figure this wig wag thing out wasnt sure on what to order.. Thanks again Matt
Page generated in 0.16582 seconds with 35 queries
