Front sas leaf spring questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2012, 12:07 PM   #1
stroker00s10
Odd Man out with a S10
stroker00s10's Avatar
Default Front sas leaf spring questions
Ok I have a sas swapped s10 on leafs up front . First question why do jeeps wrong shackles at front of vehicle instead of rear ? 2nd question should my spring bolts be level front and rear thus making spring level? My setup current has front bushing mounted higher then rear shackle so prings sits at angle. any advice?
stroker00s10 is offline   Reply With Quote
Old January 17th, 2012, 12:37 PM   #2
GMKLR50
Broke wheeler
GMKLR50's Avatar
i have the shakle at the rear, running 4" ez ride full size chevy springs up front, and they are almost level, I cant recall if it is level or not, I can check when i get home but i think they are level from spring eye to spring eye.
GMKLR50 is offline   Reply With Quote
Old January 17th, 2012, 12:53 PM   #3
stroker00s10
Kinda what i thought Most likely I need to cut out my front bar and lower it 2 inch let me know though I would appreciate it
Old January 17th, 2012, 01:33 PM   #4
GMKLR50
Broke wheeler
GMKLR50's Avatar
what kit did you use?, I have the Sky kit, there is a 2" peice of channel that the front spring mounts are welded to, all of which sits under the frame. PM me your number and I will text you pics to night if that helps too. or sense your close you can come by and check out my set up and see everything you might be questioning.
Old January 17th, 2012, 01:50 PM   #5
stroker00s10
I copied skys cross bar but I used a set of bastard pack waggy /s10 springs. I just think I made my rear shackle mount to long so its throwing off my front eye height . Num is 810 410 6600 an white lake is not to far away be good check out someone elese rig compare to
Old January 17th, 2012, 02:17 PM   #6
GMKLR50
Broke wheeler
GMKLR50's Avatar
i will be home about 4:30 and probally in the garage tonight tieing up a couple loos ends on the blazer, if you want to come by ill text you my address....im at 59 and boggie lake road.
Old January 17th, 2012, 03:16 PM   #7
alltwistedup
alltwistedup's Avatar
My front spring eye is approx 2" higher then the rear spring eye at ride height. I use a stock Chevy shackle on the rear eye I can't remember the length and can't get under the truck to measure it.
alltwistedup is offline   Reply With Quote
Old January 17th, 2012, 07:50 PM   #8
GMKLR50
Broke wheeler
GMKLR50's Avatar
did you get my pics? do they help? If you want something more specific I can do that for you too.
Old January 18th, 2012, 11:49 AM   #9
stroker00s10
A+ for help guys yes pictures helped i need cut tabs off for front leaf mounts and extend them 2-3 inchs. Hopefully flaten spring out and I can gain some clearence between top of spring and dragbar. I am useing Blue torch fabs hi steer bracket for the dana-30-44 .
Old January 18th, 2012, 02:23 PM   #10
GMKLR50
Broke wheeler
GMKLR50's Avatar
not sure who made mine, but you will need that clearance for the high steer set up
Old January 18th, 2012, 03:03 PM   #11
alltwistedup
Found a pic of mine if it helps still had not put the track bar in yet. My spring pack is different then most as I have a lot of weight to control. My steering does not rub the springs at all. The mounts and cross member are recessed into the frame not stacked under it like most people do.
Page generated in 0.93029 seconds with 56 queries
