1978 k10 fuel gauge/sending unit questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2012, 02:27 PM   #1
kyl_maxwell
kyl_maxwell's Avatar
Default 1978 k10 fuel gauge/sending unit questions
My truck has twin tanks but the left one leaks badand the tank switch doesn't work so I only use the right(pass) tank, the fuel gauge didn't work in the old gauge cluster so I put a 1973 cluster in it and I know this gauge works. If I took the wire that comes outta the right(pass) side tanks and hooked it up directly to the fuel gauge wire in the back of the gauge cluster it should work right, right? It reads way past full now could the sending unit be bad itself?
kyl_maxwell is offline   Reply With Quote
Old January 15th, 2012, 04:21 PM   #2
kyl_maxwell
Help please I'm dreaming of wiring diagrams I'm looking at the so much!
Old January 15th, 2012, 08:03 PM   #3
mcampau
Yes, connecting the wire out of the working tank to the gauge directly will work. The sending unit itself absolutely could be bad. Make sure you have a good ground from the spade terminal on the sending unit to the frame somewhere. When the tank is empty it should read 0 ohms and full is 90 ohms. If you have to, remove the sender from the tank to test it.
mcampau is offline   Reply With Quote
Old January 16th, 2012, 05:09 PM   #4
kyl_maxwell
Thank you will try to test sending unit
Old January 16th, 2012, 05:11 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
don't forget to make sure the cab has a proper ground to the frame or it won't work
Yetti
Old January 18th, 2012, 06:05 AM   #6
RADRICK
RADRICK's Avatar
I just went through the same type of issue with my 80 chevy plow truck. I am pretty decent with electrical, and I wasted a lot of time trying to use the factory wiring & guage. I ended up just buying a 2" fuel guage and putting it in the factory location (my dash has factory tach). Really simple install- keyed 12v wire, ground wire, sender wire. It was like $30 bucks, and I should have done it sooner.
Page generated in 0.22133 seconds with 41 queries
