chevy 205 work w/ a C6 trans? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 12th, 2012, 04:41 PM   #1
fordman1010
fordman1010's Avatar
Default chevy 205 work w/ a C6 trans?
i was wondering if a chevy 205 case will bolt to a c 6 trans ??
fordman1010 is offline   Reply With Quote
Old January 12th, 2012, 10:40 PM   #2
Never_Evil
You will have to redrill the case and change the input shaft on the case, might be easier and/or cheaper to purchase a ford np205
Old January 13th, 2012, 12:41 PM   #3
littletrucker
I'd hit that
littletrucker's Avatar
I know you can run a ford 205 behind a chevy trans, wouldnt see why you couldnt go the other way. AA might make an adapter
Old January 13th, 2012, 01:07 PM   #4
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
Depends on which 205 case and adaptor you have. If you have a c6 case and eadaptor that has the old style 205, and you have the old style 205, they bolt up or you need to change the out out shaft, but the case have only 2 bolt patterns older and newer, I only use the old style stuff as I have lots of them.
scramblerman72 is offline   Reply With Quote
Page generated in 0.16924 seconds with 35 queries
