ZJ Super Cheap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2012, 09:50 PM   #1
hardwateraddict
hardwateraddict's Avatar
Default ZJ Super Cheap
Well thought i should post my build. Super cheap ZJ. Well I bought it cheap. Bought a TJ 4 inch lift used, all 4 springs and front shocks and front sway bar links, and set of 16x8 steel wheels, set of 235/85R16 Cooper ST's, Used rear shocks that i took off a 2003 Dakota -match the rust perfect, new holes drilled for front and rear track bars-plan on beefing up the mounts but will do for now. Well rear springs from the TJ dont fit. so used the stock front springs for the rear, and the front TJ lift springs. Worked out good. got about 900 bucks into it. Total. Next is new front track bar, current one has some play and i have a DW. Was going to buy an after market one, but i could build that for cheap, so thats the next project. Here are some pics. soon as I figure out the pic thing.
hardwateraddict is offline   Reply With Quote
Old January 9th, 2012, 09:55 PM   #2
Jeep ZJ
Jeep ZJ's Avatar
hmmmm ill have my eye on this. welcome.
Old January 9th, 2012, 10:00 PM   #3
hardwateraddict
Pics?
ID:	87714   Click image for larger version
ID:	87715   Click image for larger version
ID:	87716   Click image for larger version
ID:	87717   Click image for larger version
ID:	87719   Click image for larger version
Old January 9th, 2012, 10:01 PM   #4
Jeep ZJ
Jeep ZJ's Avatar
does the 900 include buying it??
Old January 9th, 2012, 10:17 PM   #5
hardwateraddict
Forgot to add. stock short arms. rears set close to fender but tuck up nicely. I think i will keep them. until I decide to build long arms. Thats down the road. For now need to build a front track arm. Going with fully adjustable, but undecided on what ends to use. Bushings or heims. This is my DD. What do you guys think.
Old January 9th, 2012, 10:19 PM   #6
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Looks good man! That's exactly how my little monster started out.
Old January 9th, 2012, 10:24 PM   #7
hardwateraddict
YEP! and its Super Clean. Little rusty just behind the front fenders, on the rockers. but plan on putting in some 2x4 steel all the way down for sliders.
Old January 9th, 2012, 10:26 PM   #8
littletrucker
I'd hit that
littletrucker's Avatar
Looks decent...
Old January 9th, 2012, 10:31 PM   #9
hardwateraddict
Thanks man! Yea just about how all my (little) projects start. Gears are turning in my head! Next thing ya know, 1 tons and an LS motor. or maybe a big block.
Old January 9th, 2012, 10:39 PM   #10
hardwateraddict
Originally Posted by littletrucker View Post
Looks decent...
It runs! JK, wish I had the rig that you built. Someday! Big thanks for the deal on the used parts!
Old January 11th, 2012, 07:31 PM   #11
hardwateraddict
Here is a little update. Was going to build a track arm but have a bad DW and need it gone. My track arm was whipped so needed a new one fast. One of the pics is a new MOOG Track arm, another is a better pic of how I drilled another hole for front track arm to center the axle. The other ones are some posser flex pics of the rear. Was really suprised by the amount of flex. Did remove the rear sway bar. Have some DISCOs for the front, Thanks little trucker! Will see how she flexes with them disconected. With the front sway bar links connected its not that impressive. The new track bar is really pushing my budget on this thing. I have almost a grand into it now! Yes that includes buying the ZJ. Heres a break down.
ZJ $450- guy brought into shop to have tires removed. He was taking to scrap? What? So I have to ask whats wrong. Engine knocks and leaks antifreeze. OK. I look the thing over and decide that its to clean to scrap. So I give him $450.
Knock- Free- the flywheel bolts were loose, Little locktite problem solved.
Antifreeze- $35 new water pump.
Tune up_ $50 New Cap, rotor, plugs, wires.
Oil change _ $25. Added a QT of Lucas
Another Oil Change- $25
Used TJ 4" lift.- $100- no rear shocks
Rims- $150. Bought used. like new 16x8 Steel 5 spokes. 4" backspacing.
Tires- Free. some takeoffs that I groved. 235/85/16s About 31x10.
Rear shocks- Free- Take off from 2003 Dakota. Had to do some hammering on rear mounts on the axle. Travel legth was good for the lift.
Track bar- $75. Put it on this morning before work. Still have a little DW But way better. Driveable at highway speeds.
So the total so far $910? i am sure i am missing something.
i know I am under a grand. So I am liking this project!
ID:	87777   Click image for larger version
ID:	87778   Click image for larger version
ID:	87779   Click image for larger version
ID:	87780   Click image for larger version
Old January 11th, 2012, 09:25 PM   #12
littletrucker
I'd hit that
I think Im gonna write a book... Death wobble: The saga continues.
Old January 12th, 2012, 05:04 PM   #13
Spudy
Redneck Excavator
Spudy's Avatar
Hey man i did that tj spring trick on my zj the first time around. Had a little problem with the spring rate being alot lower and would dive and what not. On the dunes i was hitting my bump stops on the woops. Mine had a 5.2 do you have the 4.0? Just some info for ya.
Spudy is offline   Reply With Quote
Page generated in 0.26481 seconds with 63 queries
