Odd 8.8" locker question. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2012, 06:32 PM   #1
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Default Odd 8.8" locker question.
I've got a 1992 Tbird 8.8' IRS under my 66 C10 - and while it was fun for awhile, I'm tired of the onewheelpeel. I'm looking for a locker, but I can't determine an exact answer for my application. The side gears in my diff are beveled at the splines - this is to help compress the snap ring that holds the halfshaft in the carrier.
My question is this -since my halfshafts are held in place by the wheel hub / unit bearing, how important is it to have the clips on the inner shaft? Seems to me that it was more of a production line aid to hold the shafts in during assembly and not structural in any way (like how C-clips keep your axle from walking out).
Thoughts?
@clarkstoncracker
Old January 9th, 2012, 08:32 PM   #2
Sandals
Fucking Zen as Shit
Sandals's Avatar
Do you have Disc brakes on top of that set-up? If they aren't holding the side gears in in any way, shape or form I can't see what it would hurt removing them.
Old January 9th, 2012, 08:53 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i would be careful with removing the snap rings because when the suspension goes through its arc the axle shafts have to expand and contract and it could be enough to pull the shafts from the diff. the cv shafts have a tripod joint to cope with this normally but it's kind of like having a slip yoke transfer case and a slip style driveshaft.
Old January 9th, 2012, 08:55 PM   #4
Would the carrier from a mark VIII fit? Majority of those were Trac Locks and IRS.
Old January 10th, 2012, 07:04 AM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Heck yeah - one of those would fit - and I'd like the aluminum lowers off of them too.
I was hoping to put a lunchbox or maybe even a selectable in there - though I guess I could always wedge an extra disc in a TRaction Loc...
@clarkstoncracker
Old January 10th, 2012, 07:05 AM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
That's the big question.
@clarkstoncracker
Old January 10th, 2012, 09:07 AM   #7
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
http://www.ringpinion.com/b2c/Produc...rand=PowerTrax
Would this work? Randy's says it fits the irs.
Old January 10th, 2012, 11:14 AM   #8
deathbypsi
Brian R.
deathbypsi's Avatar
^^ bingo. That said I built a Merkur {IRS} a while back for autocrossing and modified a Auburn posi for a GM 10 bolt it the shitty 7" rear diff and couldnt use the clips on the ends of my inner shafts. I made sure the surface on my inners had enough seal surface contact through full suspension travel and everything worked out fine. Inners had plenty of spline engagment to the spiders also.
Page generated in 0.26317 seconds with 47 queries
