Wanted: Dana 35 C-Clip spiders (pictures why). - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 1st, 2006, 02:43 PM   #1
victorymike
Geocache Addict
victorymike's Avatar
Default Wanted: Dana 35 C-Clip spiders (pictures why).
I finally found the source of my rear end rattle.
Does anybody have a set (or even the single c-clip side spider)? It is a stock dana 35 c-clip axle from a 1994 YJ with 3.73 gearing.
victorymike is offline
Old October 2nd, 2006, 06:57 AM   #2
greenmeanie
greenmeanie's Avatar
i have the whole axle; listed below with descriptions. they are 3:07 though
greenmeanie is offline
Old October 2nd, 2006, 02:47 PM   #3
victorymike
Geocache Addict
3.07 won't work...I am pretty sure those are non-c-clip axles.
Somebody has to have a set from doing a locker install.
Bueller? Bueller?
Old October 2nd, 2006, 02:53 PM   #4
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
Okay,...........How does that happen? Never seen anything like that before.
FORD FLARESIDE is offline
Old October 2nd, 2006, 03:22 PM   #5
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
It happens when there are to many little floating pieces where there shouldn't be any :tonka:
fr3db3ar is offline
Old October 2nd, 2006, 03:24 PM   #6
Icemanii
GLFWDA Land Use Committee
Icemanii's Avatar
I may be mistaken, but I didn't think the gearing mattered for the spider gears, just the R&P. THought it only made a difference on the c-clip or not.
Icemanii is offline
Old October 2nd, 2006, 03:42 PM   #7
victorymike
Geocache Addict
There were no floating pieces...that is the only spider gear with any problems...all the other spider gears are in perfect shape...more like a manufacturing defect. It is rather strange. In the 3 years I have owned my Jeep I have changed the rear differential oil 5 times...and that is without much hard 4-wheeling...so it has been well taken care of.
The gearing doesn't matter but it is an indication of what year the Jeep is which tells me if they are c-clip or not. 3.07 gearing, to me, indicates a Jeep prior to 1993/4 which means non c-clip. I have to have the recess in the spider gear to allow for the c-clip. Non c-clip=no recess=no worky for me.
Old October 2nd, 2006, 03:47 PM   #8
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I guess I'd better go look in the attic.
fr3db3ar is offline
Old October 2nd, 2006, 03:48 PM   #9
Icemanii
Icemanii's Avatar
I might have another set at the house from some given to MudnYJ when he trashed his. Will look when I get to the house this evening.
Icemanii is offline
Old October 2nd, 2006, 04:06 PM   #10
victorymike
Geocache Addict
Thanks so much fr3dB3ar and Icemanii. I am driving on pins and needles...very cautiously (and only to and from work) until I can get that spider replaced.
Upon doing some more research it seems that some TJ Dana 35s were also 3.07 geared...no idea if they were C-clip style or not. Greenmeanie's axle is out of a 1990 YJ tho.
Every time something goes wrong with my Jeep I learn lots...cool...and not so cool...at the same time.
Old October 2nd, 2006, 05:41 PM   #11
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
My 3.07 Dana 35 in my 1992 YJ has C-clips. I have side and spider gears for a D35 but you are a little ways away.
Rob the plumber is offline
Old October 10th, 2006, 03:40 PM   #12
victorymike
Geocache Addict
I am still looking. Is $89 + $11 s/h for a new set from eBay stores looking like my only possibility????
Old October 10th, 2006, 04:19 PM   #13
USMC 0369
Livin in Cal-tuckey
USMC 0369's Avatar
I really wanna help you out. I've got a set but I need them for a couple more weeks. There yours for free, except shipping please (about $9.00). But I'll need them until after the weekend of the 21st. I've snapped these before and gotten new ones for my '90 YJ out of a TJ and they slipped right in. Any C-clip D35 should work for you. So you can look as far back as 90 YJ's but probably even into the late 80's for your spider gears.
I'm taking the jeep out on the 21st, don't wanna get stranded again.
p.s. all also look into the other sites that I'm on out here in CA to see if I can scrounge some up for ya.
USMC 0369 is offline
Old October 10th, 2006, 04:48 PM   #14
victorymike
Geocache Addict
Thanks so much Chimp-O. I really appreciate the help.
Old October 11th, 2006, 10:39 AM   #15
USMC 0369
Livin in Cal-tuckey
USMC 0369's Avatar
Okay, I've got a guy that'll give me a whole Dana 35 rear axle... one axle is broken though, but you've probably already got spares for the trail (it is a Dana 35 after all). I'll arrange pick up and tear it down a.s.a.p. if you're still in need.
Lemme know.
Old October 11th, 2006, 10:42 AM   #16
Icemanii
Icemanii's Avatar
VM, looked at the gears we have and they are not c-clip style, sorry. I thought I had posted that sooner but didn't, appologize for the delay. Good luck.
Icemanii is offline
Old October 11th, 2006, 02:37 PM   #17
victorymike
Geocache Addict
Thanks for looking Icemanii.
Chimp-O...what year Jeep is the Dana 35 from? I only ask because I think something changed in the carrier and spider gears mid 1993...along with the gearing (went from 3.07 to 3.73). Looking at part numbers for the spiders...they are different for 1993/4 & up and 1987-1993. I'll PM you my number. Thanks so much for the help. I can't tell you how much I appreciate it. Oh...and I have no problem sending you the cash for the parts and shipping. Thanks man!
Old October 11th, 2006, 03:57 PM   #18
victorymike
Geocache Addict
Check this thread out dana 35\\\\\\\\\\'s have different sized spider gears?
And another Dana 35 carrier
Old October 11th, 2006, 07:27 PM   #19
Chop
Mischievous Badger
Chop's Avatar
i have a brand new set of spyder gears for a d35 c-clip rear.
$60
located in Big Rapids, Mi 49307 and will ship for $8 if need be
PM me if interested
on this site here:
http://www.drivetrain.com/dana35.htm...ential%20Parts
Std. Spider Gear Kit - pt# 707247X
Chop is offline
Old October 11th, 2006, 08:54 PM   #20
QUIETLAKE
I AM Mr. Goodwrench!
QUIETLAKE's Avatar
Send a message via ICQ to QUIETLAKE Send a message via AIM to QUIETLAKE Send a message via MSN to QUIETLAKE Send a message via Yahoo to QUIETLAKE
I really don't think gear ratio has anything to do with it. I have a used set. Also, (from being a Auto Tech), I've seen spiders WAAAAY worse, usually from spinning one tire or the other excessively w/ an open diff. Just turning normally won't cause a problem. I can part w/ them Mike...
QUIETLAKE is offline
Page generated in 0.38260 seconds with 83 queries
