headers vs. manifolds - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 8th, 2012, 06:15 PM   #1
kyl_maxwell
kyl_maxwell's Avatar
Default headers vs. manifolds
I picked up a set of cheapo headers (free) and was wondering if it was worth the time and lil bit of money involved in putting them on will it make a noticable difference or are the stock manifolds doing me fine?
kyl_maxwell is offline   Reply With Quote
Old January 8th, 2012, 06:17 PM   #2
xj97sport
atv rider
xj97sport's Avatar
What kind of engine? Whats been done to the engine?
Old January 8th, 2012, 06:17 PM   #3
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
headers all the way. I picked up a set for my lebaron a few years ago and I will say they made a huge differance
Old January 8th, 2012, 06:18 PM   #4
xj97sport
atv rider
xj97sport's Avatar
Was it turbo?
Old January 8th, 2012, 06:29 PM   #5
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Only if it was a convertible.
Old January 8th, 2012, 06:32 PM   #6
kyl_maxwell
It's basically a stock 350 guy that I bought it from said it has a small cam in it but idk, also has a edelbrock performer intake and edelbrock 650 carb
Old January 8th, 2012, 06:40 PM   #7
Rob the plumber
They are probably good for 10-15 horsepower on a stockish engine.
Old January 8th, 2012, 06:51 PM   #8
littletrucker
I'd hit that
littletrucker's Avatar
Depends on the condition of the headers, if they look good I would do it, But if they look like they are rusty or weak in anyway, toss them.
Old January 8th, 2012, 06:56 PM   #9
kyl_maxwell
They have surface rust they have been sitting around a while
Old January 8th, 2012, 07:18 PM   #10
Sandals
Fucking Zen as Shit
Sandals's Avatar
Headers can sometimes cause underhood temps to increase.
The thick casting of the manifolds helps to retain and distribute the heat, where with headers it tends to transfer to the air in the engine bay much quicker.
Just something to keep in mind for summer,
Old January 8th, 2012, 07:39 PM   #11
Rob the plumber
And don't wrap mild steel headers either. I've had one grenade on me.
Old January 8th, 2012, 07:42 PM   #12
toyota h8r
toyota h8r's Avatar
agree with this.....
my old K5 was fine with manifolds.......til i went long tubes and would get so damn hot starter would have issues cranking hot.
--Between rotting out quickly
--constant leaking
--hot as hell underhood temps
--harder acess on spark plugs(some sbc headers)
--headers are easily damaged on trucks.....(i had a large branch fling up and bent the hell out of the collector......
Ill stock with manifolds unless im building a badass motor...
toyota h8r is offline   Reply With Quote
Old January 8th, 2012, 07:48 PM   #13
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
leeking headers suck ass.
But they sound cool.
If you decide to put them on, mount them with socket head cap screws.
This will help with access to bolt them up.
dougstephvoor is offline   Reply With Quote
Old January 8th, 2012, 08:13 PM   #14
kyl_maxwell
They arnt the big long ones these dump out only about 4 inches further down then the manifold
Old January 8th, 2012, 08:16 PM   #15
kyl_maxwell
They look like the ones they would give you for a v8 swap in an s10
Old January 9th, 2012, 05:05 AM   #16
Total waste of your time other than the bling factor.
-more under hood heat
-expect exhaust leaks
-tend to rot out quickly
-need to modify exhaust to fit (probably)
-no noticeable performance increase
Old January 13th, 2012, 07:25 PM   #17
skife
skife's Avatar
also keep in mind if its a single wire O2 sensor they use the heat contained from the manifolds to stay warm. it won't read right with headers.
Old January 13th, 2012, 07:28 PM   #18
mcampau
That's not quite correct. Even with long tubes you can mount the sensor in the collector and it keep it up to temp. It takes a couple minutes for it to get to temp on a cold start but after that it's just fine.
mcampau is offline   Reply With Quote
Old January 14th, 2012, 08:24 AM   #19
skife
skife's Avatar
just going with what i read, its not hard to upgrade to a 3wire o2 sensor though.
Old January 14th, 2012, 02:17 PM   #20
1slo_camaro
LONG STORY SHORT, IM 23
1slo_camaro's Avatar
ok well i guess im the only one that feels this way but EVERY vehicle ive owned 78 c10 bbc, 75 c10 bb and sbc, 6 camaros v8s v6s, s10 4.3, k5 BUILT bbc, 1.3 tracker, and soon to be a 98 ZJ i have and always will continue to put headers on them, i hate stock manifolds. maybe its just my preference, one i like have accesability to my spark plugs (some vehicles not an issue 4.0 for instance) ive ALWAYS noticed a small amount of change in power and mpg definately worth the time and more mods to the motor the bigger gain, my reasoning behind the header theory is if you compare a header port to a manifold port the manifold is substantially smaller, my theory is if its a bigger opening it will allow the exhaust to escape a little easier because it wont be constricted to such a small area inside the manifold. under hood temps, ive never noticed any real significant change, granted im not saying youll put long tubes on your sbc and gain 500hp and be able to pull wheelies. again this is just my .02 theorys nothing proven from books or anything along those lines, just my personal history i say HEADERS FTW!
also the leaking issue, if you install the headers correctly with proper gaskets you will NEVER have a leak. install the headers with good fel-pro or equivalent gaskets, brand new bolts with lock washers (or go to parts store and buy locking bolts i.e lock wire, extended lock washers) and run the vehicle for 20 minutes let it get up to temp AT IDLE, tighten bolts down, i do this 3 times on every vehicle and only have ever had one issue and found out it was because of a bent flange
1slo_camaro is offline   Reply With Quote
Page generated in 0.43702 seconds with 83 queries
