351w build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 8th, 2012, 11:09 AM   #1
eagle-eye
Default 351w build
What pistons would i need to put into my 351 windsor to bring it to about 10:1 or 10.5:1 compression with afr 185cc heads with a 58cc chamber?
eagle-eye is offline   Reply With Quote
Old January 8th, 2012, 12:53 PM   #2
frdboy
frdboy's Avatar
This is probably the best buget pistion out there, have the block 0 decked, run a .038 head gasket and you will have just over 9.8:1.
http://www.summitracing.com/parts/PBP-P2446F-030
Old January 8th, 2012, 02:45 PM   #3
eagle-eye
arent stock 351 heads 69cc chamber?
Old January 8th, 2012, 07:06 PM   #4
frdboy
frdboy's Avatar
Depends on the year and head, casting number?
Old January 9th, 2012, 05:16 PM   #5
eagle-eye
wont have it until sometime tomorrow. I will google it to see what comes up.
Old January 14th, 2012, 02:15 AM   #6
rangerman
rangerman's Avatar
69 or 70I are the best year head for a 351w
rangerman is offline   Reply With Quote
Old January 14th, 2012, 12:12 PM   #7
eagle-eye
Is there any way to bring this to 10:1 compression without machining the block?
Old January 14th, 2012, 12:20 PM   #8
frdboy
frdboy's Avatar
What heads? You first said afr and now talking about stock heads?
Old January 14th, 2012, 02:31 PM   #9
TurdBronco
No reason to machine the block if the cylinder walls don't need it.
Change heads or pistons.
Or you could machine the heads and intake to get some more compression but then you have to check piston to valve clearance and pushrod length.
What is the goal?
10.5:1 is pushing it on pump gas depending on what the timing is at.
Old January 14th, 2012, 04:32 PM   #10
eagle-eye
Stock timing, gonna go with afr 185s with 58cc chambers and planned on switching pistons. Want amax of 10.2:1.
Old January 15th, 2012, 01:41 PM   #11
deathbypsi
Brian R.
deathbypsi's Avatar
http://www.kb-silvolite.com/kb_car/index.html
Download the catalog and go to page 36 for the 351 stuff. Lots of options to get you where you want. Have a nice chart telling you compression with different heads.
Old January 17th, 2012, 01:13 PM   #12
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
you just speak of compression...but what do you plan to run for cam? fuel delivery? Fuel type... E85? What is your goal for HP?
Old January 17th, 2012, 01:26 PM   #13
frdboy
frdboy's Avatar
With alum. heads I would not run over 10:1 on pump gas in a truck.
Old January 18th, 2012, 01:21 PM   #14
deathbypsi
Brian R.
deathbypsi's Avatar
Why not? The aluminum heads release more heat than iron heads which will allow you to run more compression before detonation starts.
Old January 18th, 2012, 01:33 PM   #15
frdboy
frdboy's Avatar
You can get away with it in a light vehicle, decent sized cam and maybe a looser converter but a heavy vehicle, smaller cam, tighter converter all make it more prone to detonation. BTDT.
It also depends on how it is built, something with a dome to get compression up but way down in the hole might detonate @ 10:1 where a flattop set up with the proper quench will not.
Really depends on what the OP's supporting parts, what fuel, uses, and goals add up to.
That said, most people don't have near the compression they think they do, heads and pistons are normally not what they are advertised, pistons are left down in the hole .030", the volume above the ring lands and not accounted for ect.
Old January 19th, 2012, 09:49 AM   #16
eagle-eye
the cam is going to be of comp cams variety #35-424-8. Fuel delivery is going to be efi with an edelbrock truck intake. 30LB. injectors with a calibrated maf, twin 56mm throttle body, afr 185 heads with 58cc chambers. The goal is to knock on between 400-450hp's door.
Old January 19th, 2012, 10:08 AM   #17
frdboy
frdboy's Avatar
That cam is a retrofit for older blocks, don't you have a roller block? If so you will need something like this. 35-328-8
Old January 19th, 2012, 01:59 PM   #18
eagle-eye
what is categorically classified as a roller block? is it where there are two threaded posts in the valley? if that is the case then i dont have a roller block.
Old January 19th, 2012, 02:55 PM   #19
frdboy
frdboy's Avatar
Yeah it should have the bosses to bolt the lifter retainer to. What is the casting number above the starter?
Old January 20th, 2012, 11:07 AM   #20
TurdBronco
400 hp is a long shot. You have to do more than just bolt stuff on to a 351w to get 400hp.
Page generated in 0.30008 seconds with 83 queries
