22r wont stay running? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 6th, 2012, 12:26 PM   #1
isuzutruggy?
Kreepy Krawlerz Off Road
isuzutruggy?'s Avatar
Angry 22r wont stay running?
22r idles fine, but when I try to go down the road it acts like its running out of gas? It has a full tank. I changed the fuel filter on the frame rail, put some dry gas in the tank, it has a fairly new fuel pump. What else could it be?
isuzutruggy? is offline   Reply With Quote
Old January 6th, 2012, 01:42 PM   #2
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Tank pickup?
Old January 6th, 2012, 01:55 PM   #3
isuzutruggy?
Originally Posted by 974x4Taco View Post
Tank pickup?
That's new too
Old January 6th, 2012, 02:04 PM   #4
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
ignition timing? or isn't the 22r carby? accelerator pump? and jsut because a fuel pump is new doesn't mean it hasn't gone bad.
Old January 6th, 2012, 02:17 PM   #5
isuzutruggy?
Yes its carb'd, typically when the fuel pump goes bad they just stop working. Its a mechanical one
Old January 6th, 2012, 03:11 PM   #6
If its a fuel delivery problem, try splicing in a low pressure fue pressure gauge in right before the carb. l
It could also be something in the carb itself, squirts enough from the idle circuits but not putting out enough when you get on it. Float setting wrong.
Check timing as well. Check vacuum lines.
Old January 6th, 2012, 05:15 PM   #7
isuzutruggy?
Tore the carb apart, had a little bit of dirt in the bowl, what do you mean by float setting wrong? Its not sticking or anything. Someone told me I had to big of tires on stock gears and that might be why its not running right? I have 35's on stock gears. I didnt think that would matter.
Old January 6th, 2012, 05:36 PM   #8
solid95yota
"the wonder truck"
solid95yota's Avatar
no just cuz you have bigger tires isnt going to make it die. just be very very slow
solid95yota is offline   Reply With Quote
Old January 6th, 2012, 06:03 PM   #9
isuzutruggy?
thats what i thought!
Old January 11th, 2012, 06:44 PM   #10
isuzutruggy?
put an electric fuel pump on it and now it runs like a champ
Old January 12th, 2012, 02:45 AM   #11
alaska907
what do your spark plugs look like are they black of are they a nice brown
alaska907 is offline   Reply With Quote
Page generated in 0.30518 seconds with 56 queries
