Dodge 360 questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2012, 12:07 AM   #1
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Send a message via AIM to dakotaguy1
Default Dodge 360 questions
So i'm going to be putting a new **prolly used** motor in my 1998 dodge ram, and have a couple questions. I would like to get a motor with under 150k.
1) Will any year 5.9 work?
2) I would like to put headers and throttle body spacer, but would it be worth putting a cam in a motor with that many miles? and what cam would be good?
3) Is there any other way to get power out of these?
Any advice or criticism that would help
dakotaguy1 is offline   Reply With Quote
Old January 5th, 2012, 12:52 AM   #2
jeepjumper
Does not own a jeep...
jeepjumper's Avatar
I put a 99 360 in my 95 and from what i rememberd it all pluged right in...i had a problem with the factory alarm though, it wouldn't let it start so i had to pull the dash and put a junk yard harness in
jeepjumper is offline   Reply With Quote
Old January 5th, 2012, 12:56 AM   #3
noodles
give 'er sh*t ay?
noodles's Avatar
you need a magnum motor. I believe its 1994 and newer. I would watch out for egr on certain years if yours doesn't have it. From the research Ive done, the LA motors are pretty interchangeable with in the major year bands.
If you have the engine out, that would be the time to put a cam in. I didnt notice that much of a difference in power on my 318, but I just put a rv/towing cam in. pretty mild.
The best thing I did for power was stroked the engine. I can tow a 4000 lb car on my flat bed trailer and never break out of overdrive when on the freeway heading to south haven from holland. The only issue I do have is that the computer isn't happy with the displacement. I havent found a good option for my truck due to its a 94 (obd1) but with the obd2 there is alot more computer options out there.
Old January 5th, 2012, 10:35 AM   #4
DodgeDude99
the throttle body spacer is nothing more than a paper weight.
94-02 were the magnum years, egr i believe stopped with the obd2 in '96.
comp has a series of cams for the magnums
mods besides the stroker...
ported throttle body
RHS or Edelbrock cylinder heads
Harland Sharp 1.7 roller rockers
modded stock kegger intake manifold or Hughes' Air Gap manifold (Hughes claims more power & mpg)
headers
Hypertech, Superchips & SCT offers handheld tuners.
SCT offers the ability for custom tunes, B&G Chrysler will also do a custom flash if you give them all the specs of your build.
DodgeDude99 is offline   Reply With Quote
Old January 5th, 2012, 06:24 PM   #5
junkyardjon
93 was the first year of the 5.9 magnum
92 for the 5.2 if it matter's
junkyardjon is offline   Reply With Quote
Old January 10th, 2012, 04:46 PM   #6
rammanriley
rammanriley's Avatar
FWIW I put a engine from a 98 in my 96 Both 5.9l. Only issue I had was some of the newer sensors used different connectors do i had to use a couple from the 96 (tps is the only one I can think of right now).
rammanriley is offline   Reply With Quote
Old January 26th, 2012, 11:18 AM   #7
haybob
I put a 99 in my 98 the alt was different. cut the runners on you stock intake. for a couple hrs of work its well worth it!
haybob is offline   Reply With Quote
Old January 26th, 2012, 11:20 AM   #8
haybob
oh ya timeing chain and gears, a good ideal any time your putting in a used engine and u want it to last! cheap insurance
Page generated in 0.27988 seconds with 47 queries
