5.3 heads - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2012, 03:58 PM   #1
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Default 5.3 heads
Are 1999 5.3 heads worth a crap for performance? Will they bolt onto a 6.0? I have a set and was wondering if it was worth porting and polishing to put on a 6.0.
Old January 3rd, 2012, 04:11 PM   #2
montecarlo33
The Violator
montecarlo33's Avatar
862's I imagine? They would bolt up to a 6.0 but Im not sure that it would gain you anything over stock 6.0 heads that would make the money worth the while.
Old January 3rd, 2012, 04:16 PM   #3
chadcooper55
I have never ported and polished heads before but i would like to try it. Just figure if they aren't terrible heads I would do it to them. I'm not out anything if I fukc it up and I could always put the stock heads back on the motor.
Old January 3rd, 2012, 10:36 PM   #4
welderbrian
welderbrian's Avatar
I have a set going on my new motor had the machine shop open up for 6.0 intake valves I believe the added compression is worth more than the flow gained from 6.0 heads in useable power that the motor will see.
welderbrian is offline   Reply With Quote
Old January 6th, 2012, 12:57 PM   #5
montecarlo33
The Violator
Probley just like throwing 305 heads on a 350 does the same for a bump in compression.
Old January 6th, 2012, 01:41 PM   #6
2000_WJ
2000_WJ's Avatar
They could be 706 castings also. What head castings are on your 6.0L 317?. 5.3L heads dont flow as well as a 243 head, they are similar in flow to a 853 but have smaller combustion chambers. These heads with the LS6 valves, porting and decking used to be the standard for 3rd gen LS cam and head cars.
2000_WJ is offline   Reply With Quote
Old January 6th, 2012, 02:10 PM   #7
chadcooper55
I haven't bought the 6.0 yet, I am still researching. I will check the 5.3 heads when I get home, I am in Colorado working right now.
Old January 6th, 2012, 03:44 PM   #8
Yeah, those are 'standard' 5.3 heads, they'll bump compression. Its a popular option on 6.0s, once ported. A lot of companies sell ported 5.3s as cheap performance heads.
later high output Gen III and Gen IV 5.3s have better heads, the 243 / 799 heads (so called 'LS6' or LS2 heads). They flow better but don't do the same bump in compression.
You can also mill them for more compression. With any of the heads, especially since all of these are smaller valve catherdral port heads.
The 6.0 heads flow well, but have a larger chamber volume. So milling those and doing a P&P might be another option.
The hot ticket (but takes some money) is putting L92 square port heads (about $900 a pair), and matching intake.
Old January 6th, 2012, 09:19 PM   #9
chadcooper55
So bang for my buck It would be worth doing a little work on the 5.3 heads? I want to build a budget performance 6.0. Nothing extreme but I would like it to be peppy. Spending less on the motor makes it easier to swallow the price tag for an atlas.
Old January 13th, 2012, 10:28 PM   #10
jordanpetruska
jordanpetruska's Avatar
one of my buddies did this alittle bit ago. alittle higher compression. the porting and polishing is pretty easy to do yourself. we just did the head on my jeep motor just for the hell of it. im sure it wont make a damn bit of difference, but we did it anyway.
jordanpetruska is offline   Reply With Quote
Old January 13th, 2012, 10:33 PM   #11
chadcooper55
I'll have to talk to your buddy before I do it jordan. Did you get you jeep running good yet?
Old January 14th, 2012, 07:59 AM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Chad, if you want - I can show you how to build a DIY flowbench and give you a few caveats on port shaping. Many heads benefit from material being *added* in addition to removed.
@clarkstoncracker
Old January 14th, 2012, 10:29 AM   #13
chadcooper55
That would be awesome scooter! I would really appreciate it. I really want to learn how to do it correctly.
Page generated in 0.40552 seconds with 62 queries
