85 toyota pickup mods????? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 1st, 2012, 10:31 PM   #1
alaska907
Default 85 toyota pickup mods?????
i jest got an 85 toyota pick up with a 7 inch lift with 39.5 super swamer boggers powerd by the 22RE i put a headed on it an i was wondering if there was any big power adders i could do to the motor
alaska907 is offline   Reply With Quote
Old January 2nd, 2012, 01:45 PM   #2
generalyota
Ridge Runners Offroad
generalyota's Avatar
you can throw a turbo at it and a larger cam. thats about it without spending alot of money for 200 ponies.
generalyota is offline   Reply With Quote
Old January 2nd, 2012, 01:48 PM   #3
isuzutruggy?
Kreepy Krawlerz Off Road
isuzutruggy?'s Avatar
did you put any gears in it? a cam will help alot, headers. thats about it without spending a bunch of money
You have any pics of the truck you can post?
isuzutruggy? is offline   Reply With Quote
Old January 2nd, 2012, 08:01 PM   #4
alaska907
it seams to be geared right an i got a headman header on it right now i also moved the raidator to the bed of the truck with dule electric fans
Old January 2nd, 2012, 09:48 PM   #5
isuzutruggy?
do you know what gears you have?
Old January 2nd, 2012, 10:02 PM   #6
I suck cocks. Lots of them.
locally famous
do you have seat covers?
Old January 3rd, 2012, 02:38 AM   #7
alaska907
i cant remember off the top of my head what the gears are in it. no i dont have any seat covers. in low range thow with the bogger i can get into 3rd gear an throw sum mud like no other is there sum aftermaket EFI for the 22re?????
Old January 3rd, 2012, 02:49 AM   #8
snow-turtle
Selective Hearing
snow-turtle's Avatar
x2 seat covers
http://www.lceperformance.com/EFI-Po...-p/1020009.htm
http://www.lceperformance.com/22RET-...-p/1060008.htm
http://www.lceperformance.com/22RE-8...-p/1060002.htm
snow-turtle is offline   Reply With Quote
Old January 3rd, 2012, 11:28 AM   #9
BOGDOG
BOGDOG's Avatar
Why would you want an aftermarket EFI for a 22RE? I doubt that it would gain much HP over the stock EFI. I hate to say it but small block chebby would probably be your best bang for the buck. Although the biggest bang might be from your axles.
Old January 3rd, 2012, 05:44 PM   #10
alaska907
thank you snow-turtle!!!!!!! yea there is enuff room to put a sb in it iv seen them with383 stroker in them but i wanna keep this truck light as possable. but you do make a good point you put a small block in a 4000 lbs truck an nothing is gonna stop you
Old January 4th, 2012, 04:34 PM   #11
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Your truck is well under 4k lbs.
Bogdog hit the problem perfect. Your stock axles will nor tolerate 40" boggers long, eslecially with anything more than a stock 22re. And while there are ways to add power to a 22re, most of them are pricey and not really worth it imo. Your best bet is a bigger motor if you have to have more power.
974x4Taco is online now   Reply With Quote
Old January 4th, 2012, 04:53 PM   #12
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Some thing to think about...a 22re dry weight is 315 lbs, mean while an all aluminum gm v-8 (ls1, l33 5.3, ect) is 480 lbs, that is a 165 lbs for 3x the power.
*these numbers are the result of a quick search, I cant verify accuracy*
Old January 8th, 2012, 04:05 PM   #13
alaska907
yea but ya gotta acount for the new axles drivlines tranny the orignal axles will never withstand the abuse of a 350
Old January 8th, 2012, 04:31 PM   #14
motocrosstcw
motocrosstcw's Avatar
I also agree, I swapped to 305 when i built mine.
motocrosstcw is offline   Reply With Quote
Old January 8th, 2012, 04:32 PM   #15
isuzutruggy?
those axle's will hold up fine if there are built with the right parts
Old January 8th, 2012, 07:51 PM   #16
alaska907
what all ya have to do when you put it to a 305
Old January 9th, 2012, 12:02 AM   #17
isuzutruggy?
everything you need is here
http://www.trail-gear.com/axles-and-service-parts
Old January 9th, 2012, 08:22 AM   #18
Actually, 425-430 lbs for an aluminum block LSx motor, fully dressed. Same weight as a 4.3 V6. I've personally hung one from a scale and weighed them.
Old January 9th, 2012, 11:19 AM   #19
BOGDOG
BOGDOG's Avatar
I'd be suprised if they hold up to the 39" tires for very long.
Old January 9th, 2012, 12:46 PM   #20
Bad_Vision
Bad_Vision's Avatar
http://www.summitracing.com/search/B.../?autoview=SKU
i would go with the 4.3l vortec motor. if you don't want a bulky v8 that could cause axle damage you'll get a increase in power but not over power your rig.
Bad_Vision is offline   Reply With Quote
Page generated in 0.48741 seconds with 83 queries
