I have a couple questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 1st, 2012, 10:50 PM   #1
chevy_4x4_trucks
chevy_4x4_trucks's Avatar
Default I have a couple questions
so ive got a 4l60e that came out of a 99 jimmy with approx. 160,xxx miles and my buddy wants to put it in his 2003 suburban. my questions are 1, how much do you think the trans is worth and 2 any idea if it would actually fit in his burban. and advice would help. thanks in advance
chevy_4x4_trucks is offline   Reply With Quote
Old January 1st, 2012, 11:06 PM   #2
skife
skife's Avatar
most likely it'll fit in his burb, but i'm not sure if everything will plug and play.
160k? i'd say it probably will need a rebuild soonish... $200-300 if everything worked when it came out.
Old January 1st, 2012, 11:16 PM   #3
s10v8zach
JACK STAND WHEELER
s10v8zach's Avatar
the trans will not bolt in. the sub has a bolt on trans bellhousing that is longer to make up the crank difference between gen 2 and gen3 smallblocks (i belive its .400 difference)
s10v8zach is offline   Reply With Quote
Old January 1st, 2012, 11:35 PM   #4
chevy_4x4_trucks
you talk like you have ran into this problem before Zach so i take it ur sure about it?
Old January 1st, 2012, 11:56 PM   #5
s10v8zach
JACK STAND WHEELER
s10v8zach's Avatar
Yes i just delt with this last week on a 96 chevy half ton. the guy i was helping out bought a trans from a 2003 silverado.it will bolt up but there is a huge gap between the torque convertor and the flexplate. this will show u the difference between gen 1 and gen 3 small block. hope this makes sense.
Old January 2nd, 2012, 12:51 AM   #6
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
I thought there was differences between the 4l60e in an s-10
and in a full size? Just like i thought their was differences in the t-cases as well? Is this only true if they are from different Gen motors?
I find it hard to believe that they would use the same transmissions as an s-10 in a much heavier suv with more power.
Not to Hi-jack this thread but i have always thought they were different so it would be nice to know the truth if i am wrong.
tctrojan17 is offline   Reply With Quote
Old January 2nd, 2012, 02:10 AM   #7
deerebowtie
Unchained
deerebowtie's Avatar
160k on the trans its about a donor case, that is it. Maybe 2-300$ depending on how clean it looks.
There is a complete thread on this over on Pirate, I'm trying to find a link - I'll append that when I find it.
Its not the bellhousing length, its the length of the crank. That's why manufacturer's produce a crank spacer.
Old January 2nd, 2012, 12:58 PM   #8
chevy_4x4_trucks
any possible links for the needed crank spacer
Old January 2nd, 2012, 01:01 PM   #9
s10v8zach
JACK STAND WHEELER
s10v8zach's Avatar
deere bowtie is right about it being the crank length that is off. sorry one to many beers lol.
Old January 2nd, 2012, 01:29 PM   #10
deerebowtie
Unchained
it should bolt right up to the suburban (the 5.3 should still have the spacer on it)
Old January 2nd, 2012, 04:54 PM   #11
chevy_4x4_trucks
alright well now i have someone on another forum telling me that they wont bolt together because quote "the new ls motors (5.3, 6.0) have a diff. bellhousing. you might be able to get a couple of the bellhousing bolts to line up, but not all of them" end quote...is there any truth to this?
Old January 2nd, 2012, 05:12 PM   #12
deerebowtie
Unchained
the LS motors have a bolt hole on the upper right (or left) that isn't there, that's it. everything else should swap without a hitch.
if you want a bit of a stall converter, use the S10/jimmy converter. Otherwise, buy a new converter to match the suburban.
Old January 2nd, 2012, 07:26 PM   #13
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
they are the same... I said the same thing about the 700r4's back in 84.
Page generated in 0.27745 seconds with 62 queries
