1988 yota runs then dont.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 1st, 2012, 06:10 PM   #1
kyl_maxwell
kyl_maxwell's Avatar
Talking 1988 yota runs then dont..
I have a 88 yota pickup that will run for like 10th mins and the just dies and won't start back up but if you let it sit a day or so will fire right up run for 10 mins anddd die, I'm completly stumped any help would help
kyl_maxwell is offline   Reply With Quote
Old January 1st, 2012, 07:08 PM   #2
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Does it run good when it runs?
When it dies does it just shut off or does it spit, sputter and carry on?
When it starts does it start hard?
22re?
Old January 1st, 2012, 08:31 PM   #3
kyl_maxwell
Yeah its the efi 22, yeah it runs great and starts easy like there's nothing wrong then when it starts to die it will spit and sputter just a lil bit then dies and won't start back up
Old January 1st, 2012, 08:58 PM   #4
skife
skife's Avatar
fuel?
Old January 1st, 2012, 09:02 PM   #5
kyl_maxwell
As far as I can tell its getting fuel its a new fuel pump less then a year old but would a fuel pump work for like 10 mins and quit?
Old January 1st, 2012, 09:04 PM   #6
kyl_maxwell
What stumps me is it will run fine and then bam dead I read something about the signal generator or whatever you call it in the distributor can over heat and stop work?.....
Old January 1st, 2012, 09:23 PM   #7
Motorcitydak
Merkin salesman
Motorcitydak's Avatar
Send a message via AIM to Motorcitydak
My old BMW was doing this exact same thing. I thought it was something clogging up the exhaust. It ended up being bad electrical connections/wires. Clean all of your contacts from the battery terminals, to the starter and ground especially. Also when this happens and the truck shuts down you can check all of your major wires for resistance using a multi meter. The wires were already bad and when they were getting hot, that builds up even more resistance until the voltage drops too low and it dies. When they cool down it allows enough voltage to let it run again
Is it cranking slow?
Motorcitydak is offline   Reply With Quote
Old January 1st, 2012, 09:33 PM   #8
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Try squirting fuel in the intake or starting fluid . If it fires it's the fuel pickup they are known to be clogged usually with rust .
stereoguy is offline   Reply With Quote
Old January 2nd, 2012, 01:49 PM   #9
generalyota
Ridge Runners Offroad
generalyota's Avatar
sounds like a cam or crank sensor issue. cam sensor is in the distributor. if the sensor(s) or wires to sensors are faulty and expanding apart when hot the signal drops and the ecm doesnt know where the engine is according to firing order and shuts down.
Last edited by generalyota; January 2nd, 2012 at 01:52 PM. Reason: additional info
generalyota is offline   Reply With Quote
Page generated in 0.29109 seconds with 50 queries
