00 S10 Blazer 4wd won't engage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 31st, 2011, 01:18 PM   #1
98-S10-lifted
98-S10-lifted's Avatar
Default 00 S10 Blazer 4wd won't engage
Push button 4wd.
I replaced the 4wd Actuator under the battery tray and checked the vaccum line and that is all good and checked connections.
My 4wd worked about a month and a half ago, now it won't. The lights on the push button sometimes flickers (all at the same time), sometimes just the 2hi flickers, and other times the 2hi light just stays on like it should. I push the button 4hi or even 4lo and nothing happens, no light, no shifting.
I am not sure what could be the problem now.
The blazer is a stick shift if that matters at all. Also there is a constant clicking under the glove box which sounds like the blinker and stops when I push the brake or hold down the emergency flashers. I changed the relay which solved nothing. Not sure if that would have anything to do with the 4wd problem.
Any help would be appreciated. Thanks.
98-S10-lifted is offline   Reply With Quote
Old December 31st, 2011, 01:39 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
regardless of the lights in the dash it will not shift if the T case switch is bad. the flashing is most likely telling you it can't complete the task.
Yetti
Old December 31st, 2011, 01:46 PM   #3
98-S10-lifted
I will try that next, thanks.
Old December 31st, 2011, 07:26 PM   #4
Yetti
Yetti's Avatar
Yetti
Old December 31st, 2011, 07:47 PM   #5
buttercr125
I work out
buttercr125's Avatar
Most common problem with those are the transfer case encoder motor that bolts to the side of the tcase or the transfer case control module that is located in the passenger side kick panel. If you need some more info PM me.
Old December 31st, 2011, 07:52 PM   #6
Freak
Wheelin the HD
Freak's Avatar
I've got a parts case for sale just a small crack in the houseing. Should have the sensor and a good motor. If your interusted lmk and ill make sure.
Old January 1st, 2012, 12:37 PM   #7
98-S10-lifted
Well, it wasn't the transfer case switch, on to bigger an more exspensive things. But first I am trying junkyard pieces.
Old January 1st, 2012, 02:53 PM   #8
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Mine wont drop into 4low unless its under 5mph and has the clutch in and 4high wont engage after a certain speed either. If the computer isn't happy with any of these inputs the lights will flash and what not.
Maybe check were the computer gets this information from and check there? A bad switch could be sending the wrong signal to the computer.
Edit: If you find where these switches are and figure out how to by pass them let me know. I would like to remove mine.
Old January 1st, 2012, 03:00 PM   #9
Freak
Wheelin the HD
Freak's Avatar
I could engauge my 4 high at 70mph and the only time the lights flashed was when there was wheel spin.
Old January 1st, 2012, 03:50 PM   #10
98-S10-lifted
Its just wierd because I used the 4wd not that long ago, and always engaged it at a stand still. Now it won't do anything standing still or moving.
Old January 1st, 2012, 04:13 PM   #11
Freak
Wheelin the HD
Freak's Avatar
might want to pull the motor on the case and check it. Put a cressant wrench on the shaft and twist to see if it moves freely.
Old January 2nd, 2012, 02:26 PM   #12
98-S10-lifted
Well I got a t-case encoder motor and t-case control module from the junkyard. I started with the control module to see if I get anything, then I will do the encoder motor if that fails.
Edit: After tryin it out for a day or so, absolutely nothing happened. So the junyard control module controled nothing. Back to the old one and trying out the encoder motor.
Old January 3rd, 2012, 04:36 PM   #13
98-S10-lifted
So far I am not getting anywhere, I guess I will give it a little while to reset and see from there.
Old January 3rd, 2012, 04:47 PM   #14
deerebowtie
Unchained
deerebowtie's Avatar
put a crate or something under there, see if the encoder motor even shifts.
Old January 3rd, 2012, 04:54 PM   #15
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Had this problem with my 99 sierra. The soldier cracked on the computer switch behind the dash switch where the wiring harness ties into it. I used a little butane soldiering iron and some small soldier and fixed it.
Old January 12th, 2012, 01:44 PM   #16
98-S10-lifted
Problem fixed. I gave up and just took it to the dealership and ended up being a wiring issue. Didn't get raped too bad on the cost.
Old January 14th, 2012, 10:57 AM   #17
Jeep_Shaun
Don't Fear The Jeeper
Jeep_Shaun's Avatar
I have a similar issue.. I had some help from a shop, and they told me the actuator I had was still good, so I did not replace that. (did not have 4wd at all) we replaced the transfercase switch and now I have 4 low but no 4 high, and the lights flash and sometimes work. I would like to keep the stock 4wd system, but if i need to I will just do the posi lock conversion. I am confused, any help would be greatly appreciated.
Thanks...
by the way mine is a 1995.. automatic
Jeep_Shaun is offline   Reply With Quote
Old January 14th, 2012, 11:18 AM   #18
98-S10-lifted
It was wiring on mine, I had frayed wires. I was told it was from underneath the vehicle. Can't find my paperwork but it was wires from either the encoder motor or the control module.
They way it sounds is that you have an electrical problem too and probably moved the wire enough while doing the t-case switch to get low to work. So I would say check all the wires to see if they have any bad spots.
Don't know how much money you have to work with but I took the easy way out and took it to a chevy dealer to get it fixed. $100 to "inspect it" but that cost goes towards fixing the problem. Only cost me $200 from them.
Page generated in 0.33274 seconds with 77 queries
