03 Avalanche - Starts then stalls immediatly - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 30th, 2011, 01:29 PM   #1
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
Default 03 Avalanche - Starts then stalls immediatly
2003 Z71 Chevy Avalanche. I can start the truck, then it runs for a second or two normally and either sputters and shuts off, or shuts off immediately. I changed the fuel filter but it didn't help. No check engine lights come on.
I cleaned the air filter, cleaned the intake with a gumout and a toothbrush. checked for spark - good.
I turn the key forward and can hear the fuel pump kick on for a brief second. Any ideas???
"It's better to burnout than to fade away!"
MT-Dawg is offline   Reply With Quote
Old December 30th, 2011, 02:16 PM   #2
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Theft system?
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old December 30th, 2011, 02:20 PM   #3
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Key switch?
Old December 30th, 2011, 03:02 PM   #4
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
The light does not come on for the theft system. I turned the key forward and waited to see if the theft system "lock" light came on....nothing. Is hit the lock / unlock button to try to reset the theft system, but that didn't work. I didn't think it would start if the theft system was active. I'm still baffled?
Old December 30th, 2011, 03:14 PM   #5
IFS SUCKS
I like trees
IFS SUCKS's Avatar
30 Minute Learn Procedure
1.
Turn ON the ignition, with the engine OFF.
2.
Attempt to start the engine, then release the key to ON; the vehicle will not start.
3.
Observe the SECURITY telltale; after approximately 10 minutes the telltale will turn OFF.
4.
Turn OFF the ignition, and wait 5 seconds.
5.
Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes; the vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important: The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6.
Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
7.
With a scan tool, clear any DTCs, if needed. History DTCs will self clear after 100 ignition cycles.
IFS SUCKS is offline   Reply With Quote
Old December 31st, 2011, 11:42 AM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
crank sensor wires intact? i dealt with this awhile back on a intrigue. sensor wiring was fucked up and caused the pcm to think the engine was running at 1680000 rpm. moved the wires around and problem fixed.
Old December 31st, 2011, 11:58 AM   #7
bigbchevy
missmrgreenagain
bigbchevy's Avatar
almost 2mill rpm
H.o.r.e
Old December 31st, 2011, 12:00 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Originally Posted by bigbchevy View Post
almost 2mill rpm
thats what the scan tool said. bizarre right lol
Old December 31st, 2011, 12:09 PM   #9
mjvan44
GIT UP ON HER AN RIDE!!!
mjvan44's Avatar
Flick the door locks back and forth. I had the same issue and the theft system went haywire. Happened to mess with locks and it started right up. good luck......
mjvan44 is offline   Reply With Quote
Old December 31st, 2011, 12:10 PM   #10
buttercr125
I work out
buttercr125's Avatar
True story...I went and looked at it for him. When I hooked the scanner to it and cranked it over the rpm's would go from 0 and not registering anything to a crazy number. The wires going to the crank senor where soaked in oil and shoring out. Moved the wires a little bit to separate them and it started reading fine. They wires still needed to be repaired though.
Old December 31st, 2011, 12:11 PM   #11
buttercr125
I work out
Do you have a check engine light coming on with the key on and engine off? If not you have a PCM issue more than likely.
Old December 31st, 2011, 06:42 PM   #12
firehawk
Live Action!
firehawk's Avatar
Did you check the fuel pressure?
Old December 31st, 2011, 06:46 PM   #13
unluckyal
i like to party
unluckyal's Avatar
x2... check fuel pressure should be between 50 and 60 psi on the rail. common problem even though the truck starts for a second the pump gets hot and turns off.
unluckyal is offline   Reply With Quote
Old December 31st, 2011, 06:55 PM   #14
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Sounds like an alarm issue
Old January 1st, 2012, 10:27 PM   #15
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
The fuel pressure was almost nothing. I am changing the fuel pump. Thanks for everyone's input. I should have the new fuel pump in tomorrow (Monday 1/2)...so I believe this should fix it.
Old January 1st, 2012, 10:40 PM   #16
Freak
Wheelin the HD
Freak's Avatar
My 01 would do this every so often, if I locked and unlocked the doors it would start just fine.
Old January 2nd, 2012, 11:19 AM   #17
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
New fuel pump installed and its running!
If I would have borrowed or rented a gage to check fuel pressure, I may have diagnosed earlier. But I did not have the proper tools initially. I figured when I heard the fuel pump turn on and gas squirted out when I cracked the fuel line at the fuel filter that the fuel pump was working....I learned the hard way.
Thanks to everyone for all your suggestions. The security reset info will come in handy in the future.
Old January 2nd, 2012, 11:22 AM   #18
Rob the plumber
Good to hear.
Page generated in 0.30966 seconds with 77 queries
