v10 f150 - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 28th, 2013, 06:36 PM   #41
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
thanks
sbcrichie is offline   Reply With Quote
Old January 28th, 2013, 06:55 PM   #42
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Old February 1st, 2013, 07:50 PM   #43
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
built a air box today, gonna build a steering fluid resivior to that will hang off the side of the air box.
Old February 1st, 2013, 08:59 PM   #44
IDIeselman
IDIeselman's Avatar
YOU pilgrim do great work, the attention to detail is impressive. When does the conversion kit come to market?
Old February 1st, 2013, 09:05 PM   #45
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
thanks. i dont think there is a big enough market for this conversion to put together a kit.
Old February 1st, 2013, 09:21 PM   #46
jaysusr
jaysusr's Avatar
This is truly impressive. It makes my head hurt to imagine pinning all that electronics out and figuring out how to make it work. With these kinda skills I'd guess you were a deiveability guy in a former life.
Old February 1st, 2013, 09:28 PM   #47
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
No I actually haven't had much experience with newer computer stuff, I didn't have a choice but too figure this out because I told the customer I could do it before I really understood what all was involved. I honestly thought I would have place like Howell build me a custom harness, then when I started calling around I found out no body does ford wiring.
Old February 2nd, 2013, 09:45 PM   #48
tator
tator's Avatar
You still have it in your shop I'd like to come take a look at it.
tator is offline   Reply With Quote
Old February 3rd, 2013, 07:17 AM   #49
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yea its at shop still
Old February 19th, 2013, 08:02 PM   #50
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
well got everything pretty much wrapped up but motor wont run. after some trouble shooting think i have it figured out. the old motor was a 99 so i have 99 computer in the truck well after switching to new 2003 motor truck just sputters a little and dies and gets a cam sensor code and crank sensor code so i called the ford dealer and asked if they changed the reluctor ring between the two years and he said they have different part numbers, wish i hadnt turned in the old motor for core yet the dealer is trying to get me a new ring for a 99 but its taking forever.
Old February 22nd, 2013, 12:44 PM   #51
twelve
twelve's Avatar
Did you take care of the weak plug threads before you put it in or are they good. I ask because i just changed a 5.4 in an expedition and i went ahead and pulled the heads and had the plug threads done before anything happened. I've heared V-10's have the same problem and it's cheaper and easier with the heads off.
twelve is offline   Reply With Quote
Old February 22nd, 2013, 07:44 PM   #52
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
no i didnt do anything with this motor its a reman from the ford dealer. the last motor i just put new plugs in it and didnt have any problems with that one. i think the prob is mostly neglected motors that never get the plugs changed and either the plugs start to come loose and blow out or the threads get corroded and damaged when the plugs are removed.
Old February 22nd, 2013, 07:58 PM   #53
lsxzr2
zr2 with a lsx :)
lsxzr2's Avatar
Did you ever get the issue figured out and fixed? Very nice work, most people would have given up lol.
lsxzr2 is offline   Reply With Quote
Old February 22nd, 2013, 08:13 PM   #54
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
been trying to get new reluctor ring for awhile now, dealer called today and said it was in so prob put it back together this week.
Old February 26th, 2013, 07:15 PM   #55
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
well got the 99 reluctor ring but it wasnt a direct fit on the 03 motor they must have change the thickness of the cam chain gear. so i machined a 1/4" off the back of the reluctor ring and put the motor back together and it fired right up.
Page generated in 0.32819 seconds with 69 queries
