v10 f150 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 29th, 2011, 08:51 PM   #1
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Default v10 f150
I thought i would share my latest project. 2002 f150 took out the stock 4.6 trans and transfercase and swapping in a v10 4r100 trans and transfercase out of a 2002 f350. I later found out that engine and trans must have been a old stock ford thing because the engine and trans ended up being 99.
ID:	87353   Click image for larger version
Name:	v10 swap 2.jpg
ID:	87354   Click image for larger version
Name:	v10 swap 3.jpg
ID:	87355   Click image for larger version
Name:	v10 swap 4.jpg
ID:	87356   Click image for larger version
Name:	v10 swap 5.jpg
Name:	v10 swap 6.jpg
ID:	87358   Click image for larger version
Name:	v10 swap 7.jpg
ID:	87359   Click image for larger version
Name:	v10 swap 8.jpg
sbcrichie is offline   Reply With Quote
Old December 29th, 2011, 09:05 PM   #2
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Name:	v10 swap 9.jpg
ID:	87361   Click image for larger version
Name:	v10 swap 10.jpg
ID:	87362   Click image for larger version
Name:	v10 swap 11.jpg
ID:	87363   Click image for larger version
Name:	v10 swap 12.jpg
ID:	87364   Click image for larger version
Name:	v10 swap 13.jpg
Name:	v10 swap 14.jpg
ID:	87366   Click image for larger version
Name:	v10 swap 15.jpg
Old December 29th, 2011, 09:12 PM   #3
Strangler
Strangler's Avatar
Alright.... what am I missing? The Cummings into the Chevy- that made sense to me. This? This may require some explaination.
Old December 29th, 2011, 09:16 PM   #4
tator
tator's Avatar
wow i really need to stop out and look at this.
tator is offline   Reply With Quote
Old December 29th, 2011, 09:16 PM   #5
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
The cummins chevy was my personal truck, this is for a customer and he is a ford guy that loved his truck but wanted more power for pulling his trailer full of quads.
Old December 29th, 2011, 09:18 PM   #6
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
better hurry up its almost done just waiting on stainless u bends and aluminum u bends to build the exhaust and air intake. Full stainless tig welded exhaust.
Old December 29th, 2011, 09:30 PM   #7
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
The biggest part of this project was definitely the wiring. There were alot pin differences between the v10 pcm and the 4.6 pcm and of coarse adding 2 injectors and coils, and the v10 engine harness plug is at the front driverside of the engine and the v8 is at the passenger rear so i had to extend the engine harness 3' lots of solder and heat shrinking. The truck is currently running and i have allmost everything working except the speedo, waiting to get the truck on the road to figure that one out. Looks like the two pcm's operate the speedos differently.
driveshafts
Name:	v10 swap 16.jpg
Old January 4th, 2012, 05:21 PM   #8
caveman
GeoDude
caveman's Avatar
so you didn't come back up too the shop, I take it I didn't screw up those flares....
Old January 4th, 2012, 06:53 PM   #9
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Looked good to me, they looked real close to the old ones so i think we are good. Thanks for the help!
Old January 5th, 2012, 08:43 PM   #10
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I got most of the exhaust done today just have to build the tailpipe tommorow. 2.5 off the manifolds into 3 single magnaflow race muffler into a magnaflow dual chamber muffler and 3.5 tail pipe, all stainless.
Name:	stainless exhaust.jpg
ID:	87566   Click image for larger version
Name:	stainless exhaust2.jpg
ID:	87567   Click image for larger version
Name:	stainless exhaust3.jpg
ID:	87568   Click image for larger version
Name:	stainless exhaust4.jpg
ID:	87569   Click image for larger version
Name:	stainless exhaust5.jpg
Name:	stainless exhaust6.jpg
ID:	87571   Click image for larger version
Name:	stainless exhaust7.jpg
Old January 5th, 2012, 08:51 PM   #11
boggin-machine
boggin-machine's Avatar
damn you do nice work! teach me your ways!
Old January 5th, 2012, 09:00 PM   #12
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Exhaust looks good. What Tig machine are you using?
RDK_YJ88 is online now   Reply With Quote
Old January 5th, 2012, 09:15 PM   #13
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks! first you must frocus daniel son.
Old January 5th, 2012, 09:16 PM   #14
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks! Its a miller syncrowave 250.
Old January 6th, 2012, 07:51 PM   #15
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Nice! I get to use a Syncrowave 350 all day at work. I feel spoiled compared to the other guy that gets to use the Dialarc HF
Old January 6th, 2012, 08:03 PM   #16
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I used a sycrowave 350 at my old job then used a lincoln squarewave 255 that lincoln was sweet it had digital read out pulse control and all the bells and whistles id love to get ahold of one of those, but now it sounds like miller dynatsy is the only way to go if you got $$$$
Old January 6th, 2012, 08:24 PM   #17
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I'd settle for a dialarc in my own garage I do like using pulse though.
Old January 6th, 2012, 09:04 PM   #18
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Got the rest of the exhaust done today. I was quite impressed with how it sounds quiet at idle and a nice deep v10 bark when you blip the throttle.
Name:	stainless exhaust8.jpg
ID:	87600   Click image for larger version
Name:	stainless exhaust9.jpg
ID:	87601   Click image for larger version
Name:	stainless exhaust10.jpg
ID:	87602   Click image for larger version
Name:	stainless exhaust11.jpg
ID:	87603   Click image for larger version
Name:	stainless exhaust12.jpg
Name:	stainless exhaust13.jpg
ID:	87605   Click image for larger version
Name:	stainless exhaust14.jpg
Old January 24th, 2012, 07:36 AM   #19
caveman
GeoDude
caveman's Avatar
done yet? where's the burnie pictures?
Old January 24th, 2012, 09:23 AM   #20
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Nope not done yet, been waiting on parts to hopefully fix the vss compatibility problem. You will have to ask the owner for burnie pics when its done. lol
Page generated in 0.43365 seconds with 84 queries
