01 Blazer belt noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2011, 09:33 PM   #1
chevykid389
chevykid389's Avatar
Default 01 Blazer belt noise
hows it going having a squealing problem coming from my belt on my 01 blazer 4.3 liter and im trying to get some input as to what I should check next
my alternator went bad a few days ago so I went to replace it along with a new belt to hopefully try and take care of this belt noise. after replacing the alternator and belt everything was fine for about 2 hours. after 2 hours of driving the belt noise has come back. since then ive replaced the belt again along with the idler pulley and belt tensioner and its still making a lot of noise. ive also spun every pulley and haven't heard a thing. anybody else with a 4.3 have a similar problem any advice would be great
chevykid389 is offline   Reply With Quote
Old December 28th, 2011, 03:31 PM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You have A/C? The bearing is going in my van and makes more of a growling noise, but sometimes it squeels.
@clarkstoncracker
Old December 28th, 2011, 03:50 PM   #3
94cherokeemike
IT'S A XJ THING
94cherokeemike's Avatar
did u buy the cheap belt or the expensive belt?
94cherokeemike is offline   Reply With Quote
Old December 28th, 2011, 06:19 PM   #4
chevykid389
Well I tried almost every type Of belt u can try and it's def not the ac compressor
Old December 28th, 2011, 06:30 PM   #5
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
idler pulley. Bearings going out in it or dry? Happened to my GFs Jimmy.
Old December 28th, 2011, 08:48 PM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Is it the correct size and not to loose?
Old December 29th, 2011, 05:44 PM   #7
chevykid389
Replaced the idler and everything seems right noise goes away when new belt is installed then comes back shortly after
Old December 29th, 2011, 08:56 PM   #8
mcampau
Did you check alignment of all the pulleys with a straight edge or something similar?
mcampau is offline   Reply With Quote
Old December 30th, 2011, 08:41 AM   #9
chevykid389
will try this today
Page generated in 0.21187 seconds with 50 queries
