Good Source for Gear Setup Specs. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 26th, 2011, 12:22 AM   #1
BowtieWrangler
BowtieWrangler's Avatar
Default Good Source for Gear Setup Specs.
Is there any books or links to the torque specs and preloads for ring and pinion installs. I've been looking at several links with varying specs, from Randy's(Yukon), chiltons, other sites for example the dana site. For the most part they all seem to be pretty different and the specs on Randy's seem to be on the low side for example on the Dana 44 front of a dodge ram. I am just wondering if there is just a catalog or chart that is top dog when it comes these specs?
BowtieWrangler is offline   Reply With Quote
Old December 26th, 2011, 08:38 AM   #2
Tab
Tab's Avatar
The little booklet you get with a set of yukon gears from randy's is pretty handy. All the specs are on the back cover and I always seem to have 3 or 4 of those laying around.
Old December 26th, 2011, 10:54 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
If you're using OEM parts, then OEM specs should be used. I would never torque a ring gear bolt to OEM spec when using an aftermarket gear.
x2. Never had any issues using these specs.
Old December 26th, 2011, 11:57 PM   #4
BowtieWrangler
thanks a lot ill use randy's i just wanted to make sure the source i used had good results on final setup
Old December 29th, 2011, 02:00 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
get the randys bible
H.o.r.e
Old January 3rd, 2012, 02:36 AM   #6
BowtieWrangler
is this what you are refering to as randy's bible? http://www.ringpinion.com/b2c/Produc...ing_and_Pinion
Page generated in 0.17616 seconds with 41 queries
