Air shocks and Air bumps - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 24th, 2011, 09:53 AM   #1
Torg38
TorgFab
Torg38's Avatar
Default Air shocks and Air bumps
When using Air shocks do I need to run bump stops? Being that the design of both are similar and the spring rate for both become exponential near full compression. Do I need both???
Torg38 is offline   Reply With Quote
Old December 24th, 2011, 09:59 AM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I have air shocks and just some rubber bumps cause I would rather have it bottom out on the bumps vers the shock tubes
H.o.r.e
Old December 24th, 2011, 10:46 AM   #3
Probably a 2 part answer. I don't think you need them if you are not racing .... and .... your shocks are properly tuned. You have it right, they are self damping when reaching full compression. I never bottom mine out (see disclaimer below) and I've hit the whoops at Silver Lake way harder than I should. But, it's all in the tuning and air pressure. I have 12" shocks and run about 5" exposed rod at the dunes. When hitting things hard, if you look at the seal wipe on the rod, I usually stop about 3/4 - 1" from full bottom. On the other hand, I run about 3 1/2" exposed when rock crawling. If I hit some high speed stuff in that condition, yes, I have bottomed out a couple times.
So, the second half of the answer is yes, you need them if you are never going to change your air pressure and risk compromising them... or if you are going to race.
Old December 24th, 2011, 11:26 AM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
You can avoid bottoming out the shocks by setting your bump stops so the bottom out 1/2 inch before you're shocks do
H.o.r.e
Page generated in 0.23280 seconds with 35 queries
