Welding a d44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 23rd, 2011, 12:40 AM   #1
rentalrider
rentalrider's Avatar
Default Welding a d44
Well I am looking to lincoln lock the rear axle of my 79 cherokee chief s. Its got the 360, t18, Dana 20 and 44s front and rear. My question is not how to weld it but if you think it will hold up. I've had several other true lockers in front and rear axles but never had a welded axle in as long a wheelbase as this. Btw I'm running 35-17.5-15 tires. This is a rough budget wheeler and I'm having more fun with it than my past fancy rigs, but really miss at least one axle being locked. Thanks in advance.
Old December 23rd, 2011, 05:42 AM   #2
curbdog17
Mini Van
curbdog17's Avatar
google search fozzy locker
Old December 23rd, 2011, 11:53 AM   #3
sodapop
Support the Sport!
sodapop's Avatar
Tough question and it depends on how you drive and what you wheel on. I'm sure it could easily hold up if you wanted it too and you knew when to use the throttle. I'm also sure you could break it if you wanted too to. If you do end up breaking, stock replacement axles aren't that expensive or you could buy stronger shafts.
Old December 23rd, 2011, 06:29 PM   #4
rentalrider
Ok, thx. Biggest fear was the width of tire with locked rear
Sent from my DROIDX using Tapatalk
Old December 23rd, 2011, 07:04 PM   #5
robbietap
X2
I've run both and a locker will end up saving $ if you spend any amount on blacktop, welded rears on pavement are $ squealing away. Not to mention gets a little irritating.
robbietap is offline   Reply With Quote
Old December 23rd, 2011, 07:16 PM   #6
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
Well I can tell you new superior alloy shafts are $202.00 each from DTS for the rear so if you break it that is where you will be.
dougstephvoor is offline   Reply With Quote
Old December 24th, 2011, 12:43 AM   #7
pigfat
GONE COMMANDO
pigfat's Avatar
mini spool dont weld it, you weaken the metal when you apply heat like that. I recommend using the mini spool over this any day and its cheap.http://www.ebay.com/itm/NEW-Dana-44-...item336f996c74 $63.
pigfat is offline   Reply With Quote
Old December 24th, 2011, 02:04 AM   #8
joe_jeep
welfare wheeler
joe_jeep's Avatar
i got a welded 3.92 and up 44 diff $40.00. im in brownstown daily, and could meet u there.
pm me if you want to. then you can save your normal diff in case you hate the welded version.
good luck!
Old January 2nd, 2012, 02:49 AM   #9
jeepguy74
jeepguy74's Avatar
if you weld yours i would say go with the fozzy locker version...this way you are only filling in the open secftions of the gears....google it you will see lots of pics...i have run this style and know a few who do also and i would say the best way ...also if you decide to go back all you have to do is replace the spider/side gears and not the whold carrier...
plus it does give a little bit..key word little..in my opnion it is easier on things over welding the hell out of everything anf the only heat added during welding is to the spider gears in a small spot rather that how people usually weld them
Old January 2nd, 2012, 02:54 AM   #10
alaska907
well if ya plan to keep in off road weld it up but as soon as you hit pavment an start making corners your gonna eventualy bust it
alaska907 is offline   Reply With Quote
Old January 2nd, 2012, 04:06 AM   #11
oz97tj
Wasn't this attached?
oz97tj's Avatar
You don't wheel anyway so it doesn't matter.
********GLFWDA.org********
Old January 3rd, 2012, 09:50 AM   #12
rentalrider
You've got a real good point! Now shut up and come north so we can go!
Old January 3rd, 2012, 01:59 PM   #13
old_red_limited
"Miss. Piggy"
old_red_limited's Avatar
I have my 8.8 welded, its on pavement more then dirt and i drive the hell out of it on and off road. Wears down tires real quick tho.... and gets annoying as hell
old_red_limited is offline   Reply With Quote
Old January 3rd, 2012, 03:48 PM   #14
oz97tj
oz97tj's Avatar
I sent you a text. I can't wait to see your rig parked not wheeling.
Old January 3rd, 2012, 03:55 PM   #15
Bo's Cj 7
Bo's Cj 7's Avatar
Its only a 44 carrier I have 2 or 3 in the garage weld it up and have fun. I have ran them before mainly in Cjs only part I didn't like was pulling into the gas station
Bo's Cj 7 is offline   Reply With Quote
Old January 4th, 2012, 07:20 AM   #16
Torg38
TorgFab
Torg38's Avatar
Minispool x2
Torg38 is offline   Reply With Quote
Old January 4th, 2012, 10:40 PM   #17
rentalrider
No text received. I call bs. You're afraid of my open/open chief.
Old January 4th, 2012, 10:49 PM   #18
I suck cocks. Lots of them.
locally famous
weld it
Old January 4th, 2012, 10:53 PM   #19
Renegade II
Coil springs are for pens
Renegade II's Avatar
Danimal has been running a welded/spool combo in his Chief for at least two-three years now and it's holding up so far with 37's and a bit of regular road usage. But he wheels like old people screw so.....
Old January 5th, 2012, 08:40 AM   #20
rentalrider
cool, thanks all for the input
Page generated in 0.40441 seconds with 83 queries
