7.3 wont start after bully dog uninstall - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 22nd, 2011, 07:48 PM   #1
zackcorey29
Default 7.3 wont start after bully dog uninstall
hello my dad has an 02 ford powerstroke and he recently installed a bully dog chip. i tried to uninstall it and install it in my 04 dodge cummins. and now his truck wont start just cranks over. if anyone has had this problem or knows what could cause it any info would be greatly apreciated. thank you very much
zackcorey29 is offline   Reply With Quote
Old December 22nd, 2011, 07:53 PM   #2
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
i could tell you that you are not very smart
Old December 22nd, 2011, 07:55 PM   #3
buttercr125
I work out
buttercr125's Avatar
x2
Old December 22nd, 2011, 08:00 PM   #4
Bleay
sick of jackstand wheelin
Bleay's Avatar
Did it ever start after uninstalling? Or did you mess up the space time continuum by trying to install a Ford programmer on your Dodge?
Bleay is offline   Reply With Quote
Old December 22nd, 2011, 08:16 PM   #5
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
How would him installing the ford programmer on his dodge cause his fathers Ford to not start?
tctrojan17 is offline   Reply With Quote
Old December 22nd, 2011, 08:20 PM   #6
Christmas Cookie
dude thats like day one shit...sounds like someone needs to go back to school
Old December 22nd, 2011, 08:20 PM   #7
Bleay
Bleay's Avatar
It wouldn't.
Old December 22nd, 2011, 08:37 PM   #8
Tom
Because racecar
Tom's Avatar
It wouldn't.
But if he didn't uninstall the tune properly it will.
Old December 22nd, 2011, 08:40 PM   #9
Bones
Bones's Avatar
This was a stacker chip I assume? Did you remove the PCM to remove the chip, or could you remove the chip without removing the PCM from the footwell area? Did you disconnect the neg battery cable while you were fussin with the PCM/chip?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 22nd, 2011, 09:01 PM   #10
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
It wouldn't.
Based on what you wrote it appeared to me as if you thought the dodge was the truck not starting.
Old December 22nd, 2011, 09:39 PM   #11
masterbeatty
masterbeatty's Avatar
Edge chips would do this occasionally. Its a theft prevention deal. You have to cycle the key so many times and watch the theft light blink if you google it tons of anwsers come up
Old December 22nd, 2011, 10:46 PM   #12
Goped_Rdr
8 Lug Thug
Goped_Rdr's Avatar
Send a message via AIM to Goped_Rdr
You might have wiped out the PCM, installing and uninstalling programmers is actually very risky if your an idiot. Prob just have to get the pcm reflashed if thats the issue. Either way I wouldnt be swapping chips from fords to dodges, that just sounds bad from the get go
Goped_Rdr is offline   Reply With Quote
Old December 22nd, 2011, 11:00 PM   #13
masterbeatty
turn your key to the on position dont crank it though your theft light should flash off and on for about 45 seconds while your ignition is in the on position. After 45 seconds the light will flash off and on every three seconds..At this time turn your ignition off for 30 seconds then start the truck.
try this first
Old December 23rd, 2011, 01:54 PM   #14
ThinICE
Awesome-O
ThinICE's Avatar
Removing a programmer or chip from the 02 7.3L PCM which results in a crank no start generally means the PCM is crap. I worked with Ford Diesels for a long time and this is not a good sign. Tow the truck to a Ford dealer, or get a cheap code scanner, and run the system for codes... no data = new PCM.
ThinICE is offline   Reply With Quote
Old December 23rd, 2011, 08:33 PM   #15
7.3X
Fullsize support vehicle
7.3X's Avatar
try this first
Give this a try and worry about the rest only if this fails.
7.3X is offline   Reply With Quote
Old December 23rd, 2011, 08:35 PM   #16
masterbeatty
again google it and you will find it is actually common that a chip or tuner will trip the theft system. before tow bills and dealer prices. how hard is it to take 20 minutes tops and try what i posted.
Old December 25th, 2011, 08:45 AM   #17
zackcorey29
thanks for the info dick heads who are just so smart its a bully dog tuner that can be ran in either ford dodge or chevy and i figured it out it ended up being a blown fuse.
Old December 25th, 2011, 08:50 AM   #18
Christmas Cookie
good thing you tried and put into a dodge then
Old December 26th, 2011, 10:33 AM   #19
ThinICE
Awesome-O
ThinICE's Avatar
Well then we have all learned something here... check the basics before hitting the forums!
Old December 26th, 2011, 11:13 AM   #20
Toivo
Feel lucky?
Toivo's Avatar
ford dodge? must be a new brand. never heard of it.
Page generated in 0.40792 seconds with 83 queries
