OBD 1 reader - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 22nd, 2011, 10:45 AM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default OBD 1 reader
I've never used one, but my father in law wants one ( especially for his 1994 Vet).
What do you recommend and where can I get one for him?
Old December 22nd, 2011, 11:24 AM   #2
Medic8
You call, we haul.
Medic8's Avatar
Shawn, 1994 Corvette was the first year for OBD2. It should use the newer style diagnostic readers. As far as which one to get, they're all basically the same unless you get an actual Tech2. Some have fancy readouts which tell you the code and what it means. The cheaper ones just tell you the code and give you a booklet to look it up.
Old December 23rd, 2011, 09:31 AM   #3
shawn
shawn's Avatar
Oh, thanks for posting up! That's good to know.
Old December 24th, 2011, 11:20 AM   #4
cerial
Direct Drive FTW
cerial's Avatar
I use/recommend them all the time over the guess/check method. I do not recommend using the "jumper wire" method. Make sure you get one that is model specific not just for GM. Know also that you should unplug the battery then drive the car in cold to hot city/highway conditions. The codes go dormant after so many cycles and unplugging the battery will reset the counter and let you see all the fault codes not just the most prominent ones.
Page generated in 0.15133 seconds with 35 queries
